I am having issues using I2C4 (controller i2c@c250000).
If I use a device tree with a device setup on I2C4 there are timeouts and read errors during boot.
If I leave the device disabled in the device tree and try to do an i2cdetect on the bus it just goes very slow and errors out.
The same device on a different bus works fine so I am confident the device tree and driver are working properly. It seems to be something on the Xavier side.
Hi kayccc,
Yes it is a custom board and the difference is we have an I2C expander connected to it. We have another I 2C expander that is identical on a different I2C bus and it works fine.
And yes it is still a support issue.
The controller might actually be i2c@31e0000 I am not sure. I have tried both.
I have also tried multiple boards so the issue doesn’t seem to be hardware related.
