Hi there, I believe I have an issue with my I2C bus with my AGX Xavier, and I’m not too sure what the fix would be.
All the USB Ports have somehow stopped working. This includes the two USB C ports, the micro usb port and the USB A port. However, the ethernet and the HDMI still works. When connected to a monitor, the login page still appears and I can ssh in through ethernet.
However, when starting it up via HDMI, the following errors appear before the login page
and when I do a “sudo i2cdetect -y -r 8”, I get this weird output as well
This leads me to suspect with high certainty that I have completely messed up the I2C bus. Any recommended paths to take from here to get everything back up and running again?
