usb port,type-c port,network port can’t use ,xavier can connect to monitor and display,but mouse and keyborad can’t work in any ports.Does anyone can help me? thanks a lot
870934239,
- Are you using devkit?
- Can dp monitor work on type c port?
- Could you see new log from dmesg if you connect usb device to usb port?
- Did you modify anything?
thanks for your reply
i just use xavier a little,so i cann not understand some of your quetion
before i download JetPack in xavier, the ports can work,but when i run the JetPack,it is arm64,need x64 can use ,then i shutdowm it,after that ,i can not use my port.
870934239,
So you don’t have a x64 host for jetpack? Just directly use the SW installed on out-of-box Xaiver?
yes,just like you said,and what’s “SW” you mention?
I mean software.
Could you find a x64 host and use Jetpack to flash your board first?
I don’t guarantee what is installed on out-of-box Xavier…
i konw your words,can you give me a guide of how to do it?
You could download jetpack from here.
Run jetpack as a binary file on your ubuntu desktop and a GUI would show.
thanks you so much,i will try it
The JetPack software runs only on desktop PCs, e.g., Intel or AMD CPU. This is x86 or x86_64 or amd64 in some abbreviations. The Jetson itself is arm64/aarch64/ARMv8-a, and the flash software won’t run on this…simply meaning an Xavier cannot self-flash.
linuxdev,
thanks for your help
dear all,i got a monitor today,when i start xavier ,he tells me to enter password,but all ports when i connect to keyboard can’t use ,what should i do?
Have you flashed the devices?
After you flash the Xavier with Jeptack, the Xaiver still cannot access usb?
how to flashed the device? i just open the device
Could you firstly study the instructions here for jetpack?
sorry, i am a fersh man,when i’m installing jetpack it tells me"error occurs during installation", i can’t install it,how to sovle this problem?
Could you paste log? Do you set the device into recovery mode?
emmm,my folder include chinese,i change the name ,it can work
Now i had flashed the devices,but the type-c port and usb port also can’t use keyboard and mouse.
My keyboard connect to usb3.1 port,the indicator light is off
