I’m developing the software support to capture video using a SERDES GSML setup with a custom carrier board. The deserializer IC and the camera module are located in the i2c-3 bus (@3190000) but I’m having issues with that bus, basically the kernel is reporting that the bus is not responding:
[ 14.459583] tegra-i2c 3190000.i2c: pio timed out addr: 0x48 tlen:28 rlen:4
[ 14.459786] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 14.459924] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 14.460027] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 14.460154] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x0
[ 14.460273] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800080
[ 14.460384] tegra-i2c 3190000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 14.460534] tegra-i2c 3190000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 14.460654] tegra-i2c 3190000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 14.460835] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 14.460946] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 14.461063] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x48
[ 24.699550] tegra-i2c 3190000.i2c: pio timed out addr: 0x30 tlen:28 rlen:4
[ 24.699765] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 24.699938] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 24.700056] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 24.700199] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x0
[ 24.700349] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800080
[ 24.700507] tegra-i2c 3190000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 24.700648] tegra-i2c 3190000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 24.700781] tegra-i2c 3190000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 24.700931] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 24.701049] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 24.701157] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x30
[ 24.701368] ov10635 3-0030: Failed to read chip ID
I have tested the i2c-3 using an original JetPack 4.2 image and the devkit carrier board and the same issue is being reported in the i2c bus when I try to scan it:
sudo i2cdetect -y -a -r 3
Does it mean this I2C bus is not enabled/available at hardware level? Any insight about this issue would be really appreciated.
Thanks,
