We want to implement new ioctl TEGRA_CAMERA_CID_GET_TSC for APP used. Kernel part do modified like below side.
- add TEGRA_CAMERA_CID_GET_TSC items
- add tegra_channel_g_ctrl for iotrl read
- add more printk for debug purpose.
diff --git a/drivers/media/platform/tegra/camera/vi/channel.c b/drivers/media/platform/tegra/camera/vi/channel.c
index 3ea2885…1df34a4 100644
— a/drivers/media/platform/tegra/camera/vi/channel.c
+++ b/drivers/media/platform/tegra/camera/vi/channel.c
+int tegra_channel_g_ctrl(struct v4l2_ctrl *ctrl)
+ struct tegra_channel *chan = container_of(ctrl->handler,
+ struct tegra_channel, ctrl_handler);
+ printk("func %s ctrl-id %d(0x%x)\n ", __func__, ctrl->id, ctrl->id);
+ switch (ctrl->id) {
+ case TEGRA_CAMERA_CID_VI_BYPASS_MODE:
+ case TEGRA_CAMERA_CID_OVERRIDE_ENABLE:
+ case TEGRA_CAMERA_CID_VI_HEIGHT_ALIGN:
+ case TEGRA_CAMERA_CID_VI_SIZE_ALIGN:
+ case TEGRA_CAMERA_CID_WRITE_ISPFORMAT:
+ case TEGRA_CAMERA_CID_LOW_LATENCY:
+ case TEGRA_CAMERA_CID_GET_TSC:
+ dev_err(&chan->video.dev, "%s: ctrl-id %u\n",
+ __func__, ctrl->id);
+ break;
+ default:
+ dev_err(&chan->video.dev, "%s: Invalid ctrl %u\n",
+ return -EINVAL;
+ return 0;
int tegra_channel_s_ctrl(struct v4l2_ctrl *ctrl)
switch (ctrl->id) {
if (switch_ctrl_qmenu[ctrl->val] == SWITCH_ON)
@@ -1051,6 +1077,10 @@ int tegra_channel_s_ctrl(struct v4l2_ctrl *ctrl)
chan->low_latency = ctrl->val;
break;
+ break;
default:
@@ -1062,6 +1092,7 @@ int tegra_channel_s_ctrl(struct v4l2_ctrl *ctrl)
static const struct v4l2_ctrl_ops channel_ctrl_ops = {
.s_ctrl = tegra_channel_s_ctrl,
+ .g_volatile_ctrl = tegra_channel_g_ctrl,
static const struct v4l2_ctrl_config common_custom_ctrls[] = {
@@ -1185,6 +1216,17 @@ static const struct v4l2_ctrl_config common_custom_ctrls[] = {
.max = 1,
.step = 1,
+ .ops = &channel_ctrl_ops,
+ .id = TEGRA_CAMERA_CID_GET_TSC,
+ .name = "TSC Value",
+ .type = V4L2_CTRL_TYPE_U32,
+ .def = 0,
+ .min = 0,
+ .max = 0xFFFFFFFF,
+ .step = 1,
diff --git a/include/media/tegra-v4l2-camera.h b/include/media/tegra-v4l2-camera.h
index 8179b3c..407c629 100644
--- a/include/media/tegra-v4l2-camera.h
+++ b/include/media/tegra-v4l2-camera.h
@@ -49,6 +49,7 @@
#define TEGRA_CAMERA_CID_SENSOR_DV_TIMINGS (TEGRA_CAMERA_CID_BASE+108)
#define TEGRA_CAMERA_CID_LOW_LATENCY (TEGRA_CAMERA_CID_BASE+109)
+#define TEGRA_CAMERA_CID_GET_TSC (TEGRA_CAMERA_CID_BASE+110)
User space do ioctrl read & write operation.
- VIDIOC_G_CTRL/VIDIOC_S_CTRL to Read and Write
The result is below.
VIDIOC_G_CTRL doesn’t work, err message is “unable to set control: Invalid argument (22)”
there is no printk message output, seems my kernel debug message doesn’t work?
If we want to add our own v4l2 ioctrl how to do it ?
struct v4l2_control ctrl;
int ret;ctrl.id = TEGRA_CAMERA_CID_VI_BYPASS_MODE;
ret = ioctl(dev->fd, VIDIOC_S_CTRL, &ctrl);
printf(“Control 0x%08x is %u\n”, ctrl.id,
ctrl.value);
if (ret < 0) {
printf(“unable to set control: %s (%d).\n”,
strerror(errno), errno);
return;
}ctrl.id = TEGRA_CAMERA_CID_GET_TSC;
ret = ioctl(dev->fd, VIDIOC_G_CTRL, &ctrl);
if (ret < 0) {
return;
Seems the new TSC ictrl has been recognized by v4l2-ctl. Ref below info
v4l2-ctl --all
Camera Controls
frame_length (int) : min=0 max=32767 step=1 default=1766 value=1766 flags=slider
coarse_time (int) : min=1 max=32763 step=1 default=1762 value=1762 flags=slider
group_hold (intmenu): min=0 max=1 default=0 value=0
hdr_enable (intmenu): min=0 max=1 default=0 value=0
fuse_id (str) : min=0 max=12 step=2 value='' flags=read-only, has-payload
gain (int) : min=256 max=4096 step=1 default=256 value=256 flags=slider
bypass_mode (intmenu): min=0 max=1 default=0 value=0
override_enable (intmenu): min=0 max=1 default=0 value=0
height_align (int) : min=1 max=16 step=1 default=1 value=1
size_align (intmenu): min=0 max=2 default=0 value=0
write_isp_format (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode (bool) : default=0 value=0
tsc_value (u32) : min=0 max=0 step=0 default=0 flags=has-payload
sensor_modes (int) : min=0 max=30 step=1 default=30 value=3 flags=read-only
