I’d like to add a joint(revolute joint) to 2-wheel Robot with ActionGraph for adding a cargo Model.
So I try to add a joint to AGV(Transporter) by using “Created Cube Mesh” for test like below.
Can you update to the latest IsaacSim 4.5, I wasn’t able to repro the issue.
although looking at your asset, you might want to add a mass API (Property panel, Add button, Physics->Mass) to both the Robot and the cargo, it seems a bit imbalanced and the wheels are not all touching the ground. and also maybe a friction material to your wheels.
