• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Jetson Orin AGX 64 GB
Deepstream 6.4
Jetpack 6.0 DP
How can I ajdust the log-level of the message broker using the python bindings - is there a property somewhere that can be set to supress all the mqtt protocol log messages?
nvmsgbroker plugin is opensource and the nvmsgbroker low-level is not opensource. you can customize the low-level lib. please find “new-api” in the doc.
please refer to \opt\nvidia\deepstream\deepstream-6.4\sources\libs\mqtt_protocol_adaptor\README. Currently DeepStream is using this mosquitto version. we did not test other mqtt versions.
