Hi there, I am trying to use IsaacLab to render some image through camera in headless mode, the problem I have is that the default RTX renderer is not accurate enough and in headless mode I cannot switch renderer to ‘RTX-interactive(Path Tracing)’ in the interface, so I want to ask how to change camera renderer with python code
At first I tried SImulationContext.set_setting(“rtx/rendermode”, “PathTracing”) and it works when there is no camera, I can verify that because when I enter the interface the renderer is already changed.
However, if I add any camera into the scene, the above code will not solve the problem(the renderer is still default and rendered image is not accurate enough) and I didn’t find any API for changing camera renderer. Do all cameras share one renderer of the scene? Do I need to use some specific kind of camera? Any help would be appreciated, below I attach my code.
@configclass
class BouncingCfg(InteractiveSceneCfg):
# ground plane
ground = AssetBaseCfg(prim_path="/World/defaultGroundPlane",
spawn=sim_utils.GroundPlaneCfg(visible=False,
physics_material=sim_utils.RigidBodyMaterialCfg(
static_friction=0,
dynamic_friction=0,
restitution=1.0,
friction_combine_mode="average",
restitution_combine_mode="average",),
size=(200, 200),
# lights
dome_light = AssetBaseCfg(
prim_path="/World/Light", spawn=sim_utils.DomeLightCfg(intensity=3000.0, color=(0.75, 0.75, 0.75))
# Prim
sphere = RigidObjectCfg(
prim_path="{ENV_REGEX_NS}/Sphere",
# sim_utils.UsdFileCfg()
spawn=sim_utils.SphereCfg(
# UsdFileCfg(usd_path="/home/xinyili/IsaacLab/Sphere.usd",
radius=1,
rigid_props=sim_utils.RigidBodyPropertiesCfg(linear_damping=0, angular_damping=0),
mass_props=sim_utils.MassPropertiesCfg(mass=1.0),
collision_props=sim_utils.CollisionPropertiesCfg(),
visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.5, 0.5, 0.5)),
static_friction=0,
dynamic_friction=0,
restitution=1.0,
init_state=RigidObjectCfg.InitialStateCfg(pos=[0, 0, 1], lin_vel=[10, 0.3, 0]),
camera = CameraCfg(
prim_path="{ENV_REGEX_NS}/front_cam", # "/World/defaultGroundPlane/front_cam",
# update_period=0.02,
height=64,
width=64,
data_types=["rgb"],
spawn=sim_utils.PinholeCameraCfg(
focal_length=24.0, focus_distance=400.0, horizontal_aperture=20.955, clipping_range=(0.1, 1.0e5)
offset=CameraCfg.OffsetCfg(pos=(0.0, 0.0, 20), rot=(1, 0.0, 0.0, 0.0), convention="opengl"),
def run_simulator(sim: sim_utils.SimulationContext, scene: InteractiveScene):
sphere = scene["sphere"]
sim_dt = sim.get_physics_dt()
count = 0
scene.reset()
# Simulation loop
while simulation_app.is_running():
if count == 0:
root_state = sphere.data.default_root_state.clone()
root_state[:, :3] += scene.env_origins
root_state[:, 7:9] = (torch.rand_like(root_state[:, 7:9]) - 0.5) * 20
sphere.write_root_state_to_sim(root_state)
scene.reset()
scene.write_data_to_sim()
sim.step()
count += 1
scene.update(sim_dt)
def main():
sim_cfg = sim_utils.SimulationCfg(device=args_cli.device, dt=0.01)
sim = SimulationContext(sim_cfg)
sim.set_camera_view([5, 0.0, 8], [0.0, 0.0, 2.0])
scene_cfg = BouncingCfg(num_envs=args_cli.num_envs, env_spacing=20)
scene = InteractiveScene(scene_cfg)
sim.set_setting("rtx/rendermode", "PathTracing")
# print("{}: {}".format("rtx/rendermode", sim.get_setting("rtx/rendermode")))
sim.reset()
run_simulator(sim, scene)
if __name__ == "__main__":
main()
simulation_app.close()
