How to change the boot logo on xaviernx on jp5.1.1
you need to change image files specified in the UEFI source code, compile it, and re-flash your device to get the logo replaced.
https://docs.nvidia.com/jetson/archives/r35.2.1/DeveloperGuide/text/SD/Bootloader/UEFI.html#customized-logo
if I build edk2, and the how to flash it to the module or packet it as a image?
just replace the file Linux_for_Tegra/bootloader/uefi_jetson.bin
with the one you build, and flash the device again.
I follow the steps of this link Build without docker · NVIDIA/edk2-nvidia Wiki · GitHub
At last, edk2-nvidia/Platform/NVIDIA/Jetson/build.sh
and it shows that prepare_stuart.sh:line 40: stuart_update: command not found
I do that in a virtual machine of ubunut 20.04.
can you check if installing this tool fixes it?
No. I delete all files and do it again
I find that it show this message at the first time
nvidia: building from workspace rooted at: /home/avcit/nvidia-uefi
nvidia: found command: python3.
nvidia: found command: virtualenv.
nvidia: found command: mono.
nvidia: found command: aarch64-linux-gnu-gcc.
nvidia: Creating Python virtual environment in /home/avcit/nvidia-uefi/venv...
created virtual environment CPython3.8.10.final.0-64 in 122ms
creator CPython3Posix(dest=/home/avcit/nvidia-uefi/venv, clear=False, global=False)
seeder FromAppData(download=False, pip=latest, setuptools=latest, wheel=latest, pkg_resources=latest, via=copy, app_data_dir=/home/avcit/.local/share/virtualenv/seed-app-data/v1.0.1.debian.1)
activators BashActivator,CShellActivator,FishActivator,PowerShellActivator,PythonActivator,XonshActivator
nvidia: Installing required Python packages...
ERROR: Could not find a version that satisfies the requirement edk2-pytool-library==0.14.0 (from -r edk2/pip-requirements.txt (line 15)) (from versions: 0.9.0, 0.9.1, 0.9.2, 0.10.0, 0.10.1, 0.10.2, 0.10.3, 0.10.4, 0.10.5, 0.10.6, 0.10.7, 0.10.8, 0.10.9, 0.10.10, 0.10.11, 0.10.12, 0.10.13, 0.10.15, 0.11.0, 0.11.1, 0.11.2, 0.11.4, 0.11.5, 0.11.6, 0.12.0, 0.12.1, 0.15.0, 0.15.1, 0.15.2)
ERROR: No matching distribution found for edk2-pytool-library==0.14.0 (from -r edk2/pip-requirements.txt (line 15))
second time
nvidia: Activating Python virtual environment.
nvidia: Updating build environment (edk2-nvidia/Platform/NVIDIA/Jetson/PlatformBuild.py).
edk2-nvidia/Silicon/NVIDIA/scripts/prepare_stuart.sh: line 40: stuart_update: command not found
I follow the steps
tianocore/edk2-pytool-extensions/blob/master/docs/user/using/install.md#installing-on-linux
But the same issue.
I set a conda env and solve it.
