How to change TX2 configuration mode to configuration 2 mode on JetPack4.2.2?
What is “mode 2” you are asking here?
Hi,WayneWWW
Sorry, I described it wrong.
Is to change the configuration of TX2 to the configuration corresponding to ODMDATA(Configuration 3).
Our customized board uses two USB3.0 and PCIe extended network cards.
I tried to change the configuration of TX2 to configuration 3 in jetpack 4.2.2, but it didn’t work.
How to modify it correctly to succeed?
lk_xiang,
It requires
If you need our help, please share your full dts which is converted from dtb and also your full boot up log.
Thank you for your suggestion
I modified the device tree file with reference to Jetson/TX2 USB - eLinux.org, but it did not succeed, and the original default configuration of USB can not be used.
p2771-0000.conf.common
process_board_version()
local board_id="${1}";
local board_version="${2}";
local board_sku="${3}";
local board_revision="${4}";
local bdv=${board_version^^};
local bid=${board_id^^};
local uboot_build=500;
local fromfab="-a00";
local tofab="-c03"; # default = C03
local pmicfab="-c00"; # default = C00
local bpfdtbfab="-c00"; # default = C00
local tbcdtbfab="-c03"; # default = C03
local kerndtbfab="-c03"; # default = C03
ODMDATA=0x6090000; # default = C0X
tegra186-quill-p3310-1000-a00-00-base.dts
#include <t18x-common-platforms/tegra186-quill-common-p3310-1000-a00.dtsi>
#include <t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi>
#include <t18x-common-platforms/tegra186-quill-camera-modules.dtsi>
#include <t18x-common-modules/tegra186-display-e3320-1000-a00.dtsi>
/* comms dtsi file should be included after gpio dtsi file */
#include <t18x-common-platforms/tegra186-quill-comms.dtsi>
#include <t18x-common-plugin-manager/tegra186-quill-p3310-1000-a00-plugin-manager.dtsi>
#include <t18x-common-modules/tegra186-super-module-e2614-p2597-1000-a00.dtsi>
#include <t18x-common-plugin-manager/tegra186-quill-display-plugin-manager.dtsi>
#include <t18x-common-prod/tegra186-priv-quill-p3310-1000-a00-prod.dtsi>
#include <t18x-common-plugin-manager/tegra186-quill-camera-plugin-manager.dtsi>
model = "quill";
compatible = "nvidia,quill", "nvidia,tegra186";
nvidia,dtsfilename = __FILE__;
nvidia,boardids = "3310:0000:A0";
nvidia,proc-boardid = "3310:0000:A0";
nvidia,fastboot-usb-vid = <0x0955>;
nvidia,fastboot-usb-pid = <0xee16>;
chosen {
board-has-eeprom;
#if TEGRA_BOOTARGUMENT_VERSION >= DT_VERSION_2
bootargs ="console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware";
#else
bootargs ="console=ttyS0,115200";
#endif
stdout-path = &uarta;
firmware {
android {
compatible = "android,firmware";
hardware = "quill";
vbmeta {
compatible = "android,vbmeta";
parts = "vbmeta,kernel,kernel-dtb,kernel-dtbo,APP,vendor,SOS";
fstab {
compatible = "android,fstab";
vendor {
compatible = "android,vendor";
dev = "/dev/block/platform/3460000.sdhci/by-name/vendor";
type = "ext4";
mnt_flags = "ro";
fsmgr_flags = "wait,avb";
odm {
compatible = "android,odm";
dev = "/dev/block/platform/3460000.sdhci/by-name/odm";
type = "ext4";
mnt_flags = "ro";
memory@80000000 {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x70000000>;
usb_cd {
status = "okay";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>;
phy-names = "otg-phy";
xotg {
status = "okay";
phy-names = "otg-usb2";
#if TEGRA_XUSB_PADCONTROL_VERSION >= DT_VERSION_2
xudc@3550000 {
status = "okay";
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>;
phy-names = "usb2";
nvidia,boost-cpu-freq = <1200>;
usb_cd {
status = "okay";
nvidia,xusb-padctl = <&xusb_padctl>;
#else
xudc@3550000 {
status = "okay";
phy-names = "usb2";
emc-frequency = <150000000>;
#endif
xhci@3530000 {
status = "okay";
//phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
//<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
//<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
//<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>;
//phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-1";
//add by lk
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>,
phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0", "usb3-1";
#else
xhci@3530000 {
status = "okay";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>;
phy-names = "utmi-0", "utmi-1", "usb3-1";
nvidia,boost_cpu_freq = <800>;
#endif
xusb_padctl@3520000 {
status = "okay";
pinctrl-0 = <&vbus_en0_default_state>;
pinctrl-1 = <&vbus_en1_default_state>;
pinctrl-2 = <&vbus_en0_sfio_tristate_state>;
pinctrl-3 = <&vbus_en1_sfio_tristate_state>;
pinctrl-4 = <&vbus_en0_sfio_passthrough_state>;
pinctrl-5 = <&vbus_en1_sfio_passthrough_state>;
pinctrl-names = "vbus_en0_default", "vbus_en1_default",
"vbus_en0_sfio_tristate", "vbus_en1_sfio_tristate",
"vbus_en0_sfio_passthrough", "vbus_en1_sfio_passthrough";
pads {
usb2 {
lanes {
usb2-0 {
nvidia,function = "xusb";
status = "okay";
usb2-1 {
status = "okay";
usb2-2 {
status = "okay";
usb3 {
lanes {
usb3-0 {
status = "okay";
usb3-1 {
status = "okay";
usb3-2 {
status = "okay";
ports {
usb2-0 {
status = "okay";
mode = "otg";
vbus-supply = <&vdd_usb0_5v>;
nvidia,oc-pin = <0>;
usb2-1 {
status = "okay";
mode = "host";
vbus-supply = <&vdd_usb1_5v>;
nvidia,oc-pin = <1>;
usb2-2 {
status = "okay";
mode = "host";
vbus-supply = <&battery_reg>;//modify by lk:org-vdd_usb2_5v
nvidia,oc-pin = <1>;//add by lk
usb3-0 {
nvidia,usb2-companion = <1>;//modify by lk:org-2
//add by lk-s
status = "okay";
vbus-supply = <&vdd_usb2_5v>;
nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
nvidia,lanes = "otg-2";
//add by lk-e
usb3-1 {
status = "okay";
//add by lk-s
//add by lk-e
#endif
pinctrl@3520000 {
status = "okay";
pinctrl-0 = <&tegra_xusb_padctl_pinmux_default>;
pinctrl-1 = <&vbus_en0_sfio_tristate_state>;
pinctrl-2 = <&vbus_en1_sfio_tristate_state>;
pinctrl-3 = <&vbus_en0_sfio_passthrough_state>;
pinctrl-4 = <&vbus_en1_sfio_passthrough_state>;
pinctrl-5 = <&vbus_en0_default_state>;
pinctrl-6 = <&vbus_en1_default_state>;
pinctrl-names = "default",
"vbus_en0_sfio_passthrough", "vbus_en1_sfio_passthrough",
"vbus_en0_default", "vbus_en1_default";
tegra_xusb_padctl_pinmux_default: pinmux {
/* Quill does not support usb3-micro AB */
usb2-micro-AB {
nvidia,lanes = "otg-0";
nvidia,port-cap = <TEGRA_PADCTL_PORT_OTG_CAP>;
usb2-std-A-port2 {
nvidia,lanes = "otg-1";
usb3-std-A-port2 {
nvidia,lanes = "usb3-1";
e3325-usb3-std-A-HS {
status = "disabled";
e3325-usb3-std-A-SS {
nvidia,lanes = "usb3-0";
pcie-controller@10003000 {
status = "okay";
pci@1,0 {
nvidia,num-lanes = <2>;
status = "okay";
pci@2,0 {
nvidia,num-lanes = <1>;
status = "okay";//modify by lk:org-disabled
pci@3,0 {
status = "okay";
i2c@3160000 {
lp8557-backlight-s-wuxga-8-0@2c {
i2c@c240000 {
clock-frequency = <400000>;
cpus {
host1x {
sor {
dp-display {
hdmi-display {
panel-s-edp-uhdtv-15-6 {
smartdimmer {
dpaux@155c0000 {
sor1 {
status = "okay";
nvidia,active-panel = <&sor1_hdmi_display>;
hdmi-display {
status = "okay";
dp-display {
nvdisplay@15200000 {
nvdisplay@15220000 {
tegra_udrm: tegra_udrm {
compatible = "nvidia,tegra-udrm";
#if LINUX_VERSION >= 414
#include <tegra186-linux-4.14.dtsi>
#endif
tegra186-quill-p3310-c03-00-base.dts
gpio@2200000 {
sdmmc-wake-support-input {
status = "okay";
sdmmc-wake-support-output {
status = "okay";
//add by lk: pcie0_lane2_mux
pcie0_lane2_mux{
status = "okay";
fixed-regulators {
regulator@1 {
gpio = <&tegra_main_gpio TEGRA_MAIN_GPIO(P, 6) 0>;
sdhci@3400000 {
cd-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(P, 5) 0>;
nvidia,cd-wakeup-capable;
i2c@3160000 {
ina3221x@40 {
channel@0 {
ti,shunt-resistor-mohm = <10>;
channel@1 {
ina3221x@41 {
channel@0 {
ti,shunt-resistor-mohm = <20>;
channel@1 {
channel@2 {
ti,rail-name = "VDD_SYS_DDR";
i2c@c240000 {
bmi160@69 {
compatible = "bmi,bmi160";
reg = <0x69>;
interrupt-parent = <&tegra_aon_gpio>;
interrupts = <TEGRA_AON_GPIO(AA, 2) 0x01>;
accelerometer_matrix = [01 00 00 00 01 00 00 00 01];
gyroscope_matrix = [01 00 00 00 01 00 00 00 01];
accelerometer_delay_us_min = <1250>;
gyroscope_delay_us_min = <1250>;
vdd-supply = <&spmic_sd3>;
vdd_IO-supply = <&spmic_sd3>;
mttcan@c310000 {
status = "okay";
gpio_can_stb = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 0) GPIO_ACTIVE_HIGH>;
gpio_can_en = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 1) GPIO_ACTIVE_HIGH>;
mttcan@c320000 {
status = "okay";
gpio_can_stb = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 6) GPIO_ACTIVE_HIGH>;
gpio_can_en = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 7) GPIO_ACTIVE_HIGH>;
ahci-sata@3507000 {
gpios = <&spmic 7 0>;
pci@1,0 {
nvidia,num-lanes = <2>;//modify by lk:org-4
nvidia,disable-clock-request;
status = "okay";//add by lk
pci@2,0 {
nvidia,num-lanes = <1>;//modify by lk:org-0
pci@3,0 {
xhci@3530000 {
//phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
//<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
//<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>;
//phy-names = "utmi-0", "utmi-1", "usb3-0";
//add by lk
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(2)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>,
phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-0", "usb3-1";
pinctrl@3520000 {
/*pinmux {
usb3-std-A-port2 {
//add by lk
pinmux {
usb3-std-A-port2 {
status = "okay";
usb3-std-A-port3 {
status = "okay";
e3325-usb3-std-A-HS{
status = "okay";
pinctrl@3520000 {
vbus-0-supply = <&vdd_usb0_5v>;
vbus-1-supply = <&vdd_usb1_5v>;
vbus-2-supply = <&battery_reg>;//modify by lk:org-vdd_usb2_5v
vbus-3-supply = <&vdd_usb2_5v>;//modify by lk:org-battery_reg
vddio-hsic-supply = <&battery_reg>;
avdd_usb-supply = <&spmic_sd3>;
vclamp_usb-supply = <&spmic_sd2>;
avdd_pll_erefeut-supply = <&spmic_sd2>;
#include "tegra186-soc-prod-plugin-manager.dtsi"
#include "tegra186-odm-data-plugin-manager.dtsi"
#include "tegra186-quill-p3310-1000-300-plugin-manager.dtsi"
eeprom-manager {
data-size = <0x100>;
boardid-with-revision = <3310>;
boardid-with-config = <3310>;
bus@0 {
i2c-bus = <&gen8_i2c>;
eeprom@0 {
slave-address = <0x50>;
label = "cvm";
eeprom@1 {
slave-address = <0x57>;
label = "cvb";
bus@1 {
i2c-bus = <&gen2_i2c>;
eeprom@0 {
slave-address = <0x51>;
bus@2 {
i2c-bus = <&gen1_i2c>;
eeprom@0 {
bus@3 {
i2c-bus = <&cam_i2c>;
eeprom@0 {
slave-address = <0x54>;
label = "cam";
enable-gpio = <2 9>;
eeprom@1 {
label = "cam";
plugin-manager {
fragment-devslp@0 {
ids = ">=3310-1000-200";
override@0 {
target = <&{/ahci-sata@3507000}>;
_overlay_ {
override@1 {
target = <&{/bpmp_i2c/spmic@3c/pinmux@0}>;
_overlay_ {
pin_gpio7 {
drive-push-pull = <1>;
fragment-e3325-xusb {
enable-override-on-all-matches;
ids = "<3310-1000-500";
odm-data = "enable-xusb-on-uphy-lane0";
override@0 {
target = <&xusb_padctl>;
_overlay_ {
ports {
usb3-0 {
status = "okay";
#else
target = <&tegra_xusb_padctl_pinmux_default>;
_overlay_ {
status = "okay";
status = "okay";
#endif
override@1 {
target = <&{/xhci@3530000}>;
_overlay_ {
#else
_overlay_ {
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>,
phy-names = "utmi-0", "utmi-1", "usb3-1", "utmi-2", "usb3-0";
#endif
override@2 {
target = <&tegra_main_gpio>;
_overlay_ {
e3325_sdio_rst {
status = "okay";
e3325_lane0_mux {
status = "okay";
override@3 {
target = <&tegra_pcie>;
_overlay_ {
pci@1,0 {
pci@2,0 {
pci@3,0 {
/* modify by lk
fragment-500-pcie-config {
ids = ">=3310-1000-500";
override@0 {
_overlay_ {
pci@1,0 {
nvidia,num-lanes = <4>;
pci@2,0 {
nvidia,num-lanes = <0>;
pci@3,0 {
fragment-comms-a00-chip {
override@0 {
target = <&bcm4354>;
_overlay_ {
sdhci-host = <&sdmmc3>;
pwr-retry-cnt = <0>;
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA_MAIN_GPIO(C, 0) 0x14>;
delete-target-property = "wlan-pwr-gpio";
override@1 {
_overlay_ {
wifi-wake-ap {
status = "okay";
gpios = <TEGRA_MAIN_GPIO(C, 0) 0>;
wifi-enable {
gpios = <TEGRA_MAIN_GPIO(B, 6) 0>;
override@3 {
target = <&tegra_aon_gpio>;
_overlay_ {
wifi-wake-ap {
/*modify by lk
fragment-500-xusb-config {
override@0 {
_overlay_ {
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>;
phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0";
#else
_overlay_ {
phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-0";
#endif
override@1 {
_overlay_ {
ports {
usb3-1 {
usb3-0 {
status = "okay";
#else
_overlay_ {
usb3-std-A-port2 {
status = "okay";
#endif
fragment-500-e3325-pcie {
odm-data = "enable-pcie-on-uphy-lane0";
override@0 {
_overlay_ {
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>;
phy-names = "usb2-0", "usb2-1", "usb2-2";
#else
_overlay_ {
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(2)>;
phy-names = "utmi-0", "utmi-1", "utmi-2";
#endif
override@1 {
_overlay_ {
ports {
usb3-0 {
#else
_overlay_ {
usb3-std-A-port2 {
#endif
override@2 {
_overlay_ {
pcie0_lane2_mux {
status = "okay";
fragment-e3320-dp {
ids = ">=3320-1000-000", ">=3320-1100-000";
override@0 {
target = <&{/host1x}>;
_overlay_ {
status = "okay";
sor {
status = "okay";
dp-display {
status = "okay";
dpaux@155c0000 {
status = "okay";
fragment-p3310-c00-comm {
ids = ">=3310-1000-800";
override@0 {
target = <&{/bluedroid_pm}>;
_overlay_ {
bluedroid_pm,reset-gpio = <&tegra_main_gpio TEGRA_MAIN_GPIO(H, 5) 0>;
fragment-p3310-c00-pmic {
override@0 {
target = <&spmic_ldo6>;
_overlay_ {
maxim,active-fps-source = <MAX77620_FPS_SRC_NONE>;
fragment-p3310-c01 {
ids = ">=3310-1000-900";
override@0 {
target = <&{/bpmp_i2c/spmic@3c/regulators/ldo6}>;
_overlay_ {
regulator-boot-on;
regulator-always-on;
override@1 {
_overlay_ {
pin_gpio2 {
pin_gpio3 {
fragment-p3310-c03 {
ids = ">=3310-1000-B00";
override@1 {
target = <&spmic_ldo8>;
_overlay_ {
regulator-name = "dvdd-pex";
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
override@2 {
target = <&spmic_ldo0>;
_overlay_ {
override@3 {
target = <&spmic_ldo7>;
_overlay_ {
The attachment is a file I have modified.
Which of the files have not been modified correctly? Please give some suggestions.
change-config.zip (12.7 KB)
log.txt (32 KB)
