Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
<Please provide details about your query/application pipeline/usecase/pictures here >
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text code:
I tried using the following code to retrieve an image with type DW_IMAGE_CPU and format DW_IMAGE_FORMAT_RGB_UINT8, but the code threw an error. I looked at the source code and found that the problem comes from dwImage_copyConvertAsync, which only supports CUDA or NvMedia images. However, CameraFramePipeline modifies the type and format in sequence, so the code below throws an error. Therefore, I was wondering if there is a function that supports modifying the format of an image with type DW_IMAGE_CPU?
std::unique_ptr<SimpleCamera> camera;
camera.reset(new SimpleCamera(paramsClient, sal, context, DW_CAMERA_OUTPUT_CUDA_RGBA_UINT8));
dwImageProperties outputProps = camera->getOutputProperties();
outputProps.type = DW_IMAGE_CPU;
outputProps.format = DW_IMAGE_FORMAT_RGB_UINT8;
camera->setOutputProperties(outputProps);
while (true)
dwImageHandle_t nextFrame = camera->readFrame();
if (nextFrame == nullptr)
camera->resetCamera();
else
dwImageCPU *imageCPU = nullptr;
CHECK_DW_ERROR(dwImage_getCPU(&imageCPU, nextFrame));
std::cout << "ok" << std::endl;
