I used the following command to update the serial number, but it didn’t work.
#sudo ./flash.sh -r -z 1234567890 jetson-xavier mmcblk0p1
After the system starts, use the following command to view the serial number.
#cat /proc/device-tree/serial-number
0423718016727
It return the old serial number.
hello yinghua.ma,
I’ve never tried this before, may I know what’s your use-case to change a serial number?
thanks
We want to make our own board. May need to write the serial number.
hello yinghua.ma,
don’t you consider for board configuration,
please check Jetson AGX Xavier Platform Adaptation and Bring-Up Guide and refer to [Board Naming] session.
thanks
Hi JerryChang,
In the future, we may need to make several versions of the carry board. In order for an image to be compatible with all versions, we may need to use the plugin-manager. As far as I know, the plugin-manger mechanism is based on eeprom.
The serial number is also in eeprom.
How to write our own serial number to eeprom?
Haven’t released software tools for flashing eeprom?
No such tools released because no need. Eeprom is through i2c so using i2cdump/i2cset should be sufficient.
How to write the eeprom on the host not on the xavier?
sorry that currently no such tool from our side.
