Software Version
[1] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[1] 1.9.10816
other
Host Machine Version
[1] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
I am trying to compile and install GitHub - NVIDIA/TensorRT: NVIDIA® TensorRT™, an SDK for high-performance deep learning inference, includes a deep learning inference optimizer and runtime that delivers low latency and high throughput for inference applications..
I tried below command:
cmake -DTRT_LIBPATH=/home/nvidia/TensorRT/ -DTRT_OUT_DIR=
pwd/out -DTRT_PLATFORM_ID=aarch64 -DCMAKE_CUDA_COMPILER=/usr/local/cuda/bin/nvcc -DCUDA_VERSION=11.4 -DTRT_LIB_DIR=/lib/aarch64-linux-gnu/ -DCUDNN_LIB=/lib/aarch64-linux-gnu/libcudnn.so -DTENSORRT_LIBRARY_INFER=/lib/aarch64-linux-gnu/libnvinfer.so -DTENSORRT_LIBRARY_INFER_PLUGIN=/lib/aarch64-linux-gnu/libnvinfer_plugin.so …
But it failed and the CMakeError.log is as below:
Compiling the CUDA compiler identification source file “CMakeCUDACompilerId.cu” failed.
Compiler: /usr/local/cuda/bin/nvcc
Build flags: -I/usr/local/cuda-11.4/targets/aarch64-linux/include;-Xcompiler=“-fPIC;”
Id flags: -v;–keep;–keep-dir;tmp;-ccbin=/usr/bin/aarch64-linux-gnu-g++The output was:
1
nvcc fatal : Stray ‘"’ characterPerforming C++ SOURCE FILE Test CMAKE_HAVE_LIBC_PTHREAD failed with the following output:
Change Dir: /home/nvidia/TensorRT/build/CMakeFiles/CMakeTmpRun Build Command(s):/usr/bin/make cmTC_99126/fast && /usr/bin/make -f CMakeFiles/cmTC_99126.dir/build.make CMakeFiles/cmTC_99126.dir/build
make[1]: Entering directory ‘/home/nvidia/TensorRT/build/CMakeFiles/CMakeTmp’
Building CXX object CMakeFiles/cmTC_99126.dir/src.cxx.o
/usr/bin/aarch64-linux-gnu-g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -DCMAKE_HAVE_LIBC_PTHREAD -std=c++14 -o CMakeFiles/cmTC_99126.dir/src.cxx.o -c /home/nvidia/TensorRT/build/CMakeFiles/CMakeTmp/src.cxx
Linking CXX executable cmTC_99126
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_99126.dir/link.txt --verbose=1
/usr/bin/aarch64-linux-gnu-g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -DCMAKE_HAVE_LIBC_PTHREAD CMakeFiles/cmTC_99126.dir/src.cxx.o -o cmTC_99126
/usr/bin/ld: CMakeFiles/cmTC_99126.dir/src.cxx.o: in functionmain': src.cxx:(.text+0x48): undefined reference topthread_create’
/usr/bin/ld: src.cxx:(.text+0x50): undefined reference topthread_detach' /usr/bin/ld: src.cxx:(.text+0x5c): undefined reference topthread_join’
collect2: error: ld returned 1 exit status
make[1]: *** [CMakeFiles/cmTC_99126.dir/build.make:87: cmTC_99126] Error 1
make[1]: Leaving directory ‘/home/nvidia/TensorRT/build/CMakeFiles/CMakeTmp’
make: *** [Makefile:121: cmTC_99126/fast] Error 2Source file was:
include <pthread.h>void* test_func(void* data)
return data;
}int main(void)
pthread_t thread;
pthread_create(&thread, NULL, test_func, NULL);
pthread_detach(thread);
pthread_join(thread, NULL);
pthread_atfork(NULL, NULL, NULL);
pthread_exit(NULL);return 0;
}Determining if the function pthread_create exists in the pthreads failed with the following output:
Change Dir: /home/nvidia/TensorRT/build/CMakeFiles/CMakeTmpRun Build Command(s):/usr/bin/make cmTC_e3bc8/fast && /usr/bin/make -f CMakeFiles/cmTC_e3bc8.dir/build.make CMakeFiles/cmTC_e3bc8.dir/build
Building CXX object CMakeFiles/cmTC_e3bc8.dir/CheckFunctionExists.cxx.o
/usr/bin/aarch64-linux-gnu-g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -DCHECK_FUNCTION_EXISTS=pthread_create -std=c++14 -o CMakeFiles/cmTC_e3bc8.dir/CheckFunctionExists.cxx.o -c /home/nvidia/TensorRT/build/CMakeFiles/CheckLibraryExists/CheckFunctionExists.cxx
Linking CXX executable cmTC_e3bc8
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e3bc8.dir/link.txt --verbose=1
/usr/bin/aarch64-linux-gnu-g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -DCHECK_FUNCTION_EXISTS=pthread_create CMakeFiles/cmTC_e3bc8.dir/CheckFunctionExists.cxx.o -o cmTC_e3bc8 -lpthreads
/usr/bin/ld: cannot find -lpthreads
make[1]: *** [CMakeFiles/cmTC_e3bc8.dir/build.make:87: cmTC_e3bc8] Error 1
make: *** [Makefile:121: cmTC_e3bc8/fast] Error 2
How to solve the problem?
