I’m trying to create a gstreamer pipeline to transcode bayer raw10 frames to H.264 using appsrc. Here’s what my pipeline looks like:
r#"appsrc name=src is-live=true block=true caps="video/x-bayer,format=bggr10,framerate=10/1,width=1920,height=1080" !
bayer2rgb !
videoconvert !
video/x-raw,format=NV12,width=1920,height=1080 !
nvvidconv !
video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080 !
nvv4l2h264enc insert-sps-pps=true maxperf-enable=1 !
h264parse !
appsink name=sink emit-signals=true sync=false caps="video/x-h264,stream-format=byte-stream""#
But I keep getting a caps non-negotiated error from GStreamer:
[ERROR farm_ng_stream::video::stream_decoder] Error { structure: Some(GstMessageError { gerror: (GError) ((GError*) 0xffff84022aa0), debug: (gchararray) "gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline1/GstAppSrc:src:\nstreaming stopped, reason not-negotiated (-4)", details: Structure(details { flow-return: (gint) -4 }) }), source: Some((Object { inner: TypedObjectRef { inner: 0xffff9823bd90, type: GstAppSrc } }, "src")), error: Error { domain: gst-stream-error-quark, code: 1, message: "Internal data stream error." }, debug: Some("gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline1/GstAppSrc:src:\nstreaming stopped, reason not-negotiated (-4)"), details: Some(details { flow-return: (gint) -4 }) }
For context, I’m trying to run this from a NVIDIA Jetson Xavier, using Jetpack 5.1.1 I have a luxonis oak-d camera and this is my depthai pipeline:
void add_to_pipeline_rgb(
std::shared_ptr<dai::Pipeline> pipeline,
ColorStreamOptions const &options,
bool data_campaign) {
auto xout_rgb = pipeline->create<dai::node::XLinkOut>();
xout_rgb->setStreamName(std::string(options.queue_name));
auto cam = pipeline->create<dai::node::ColorCamera>();
cam->setBoardSocket(to_camera_board_socket(options.camera_board_socket));
cam->setResolution(to_sensor_resolution(options.resolution));
cam->setFps(options.fps);
if (data_campaign) {
cam->setRawOutputPacked(true); // Ensure raw output is packed
cam->raw.link(xout_rgb->input);
} else {
auto encoder = pipeline->create<dai::node::VideoEncoder>();
encoder->setDefaultProfilePreset(
30, to_encoder_profile(options.encoder_options.profile));
encoder->setBitrateKbps(options.encoder_options.cbr_preferred_bitrate_kbps);
encoder->setRateControlMode(
to_rate_control_mode(options.encoder_options.rate_control_mode));
encoder->setQuality(options.encoder_options.vbr_or_mjpeg_quality);
encoder->setKeyframeFrequency(options.encoder_options.frames_per_keyframe);
cam->video.link(encoder->input);
encoder->bitstream.link(xout_rgb->input);
auto xin_control = pipeline->create<dai::node::XLinkIn>();
xin_control->setStreamName(std::string(options.queue_name) + "/control");
xin_control->out.link(cam->inputControl);
For this particular case data_campaing = true
I am confident I’m outputing bayer raw10 frames. Additionally, if I try to run my pipeline via CLI I get no errors:
GST_DEBUG=3 gst-launch-1.0 -v \
appsrc name=src is-live=true block=true caps="video/x-bayer,format=bggr10,framerate=10/1,width=1920,height=1080" ! \
bayer2rgb ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! \
nvvidconv ! "video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080" ! \
nvv4l2h264enc insert-sps-pps=true maxperf-enable=1 ! \
h264parse ! \
appsink name=sink emit-signals=true caps="video/x-h264,stream-format=byte-stream" sync=false
This is my first time ever using GStreamer, so I’m not too sure if there’s anything obvious I’m missing. Any help is greatly appreciated!
I have tried specifying caps, supressing caps, but had no success.
I expect to be able to output H.264 frames.
