Hi all!
I have read the “sample_camera_gmsl”, and it shows how to use ImageStreamer to convert a dwImageNvMedia to dwImageGL. But is there a way to convert dwImageNvMedia/NvMediaImage to OpenCV’s cv::Mat?
Hi all!
Hello taoshaoyuan,
Please see /usr/local/vibrante/docs/nvvib_docs/index.html in DrivePX2 PDK. Thanks.
OpenCV, which is required for some VisionWorks samples (and other applications), is no longer provided by NVIDIA. The NVIDIA Tegra-specific optimizations have been upstreamed to the open-source OpenCV package; instructions to download and build this package are at:
http://docs.opencv.org/master/d6/d15/tutorial_building_tegra_cuda.html
Thanks Steve,
I have already compiled OpenCV for PX2, and found a way to convert dwImageNvMedia to cv::Mat:
// create a cv::Mat from a dwImageNvMedia rgba_image
cv::Mat mat_img(cv::Size(rgba_image->prop.width, rgba_image->prop.height), CV_8UC4, surface_map.surface[0].mapping);
// convert from RGBA to BGRA
cv::cvtColor(mat_img, mat_img, CV_RGBA2BGRA);
// encode image to a jpg
cv::imencode(".jpg", mat_img, *encode_buf, encode_params);
But cv::cvtColor and cv::imencode are really inefficient, is there a way to encode an image to .jpg directly from dwImageNvMedia?
Thanks again!
hi,have u solved this issue?
Do you know how to get a cv::cuda::GpuMat from a dwImageNvMedia rgba_image?
Thank you!
Regards
hello taoshaoyuan and Steve,
According to your ideas,I still have not solve this problem,the following is my code:
void DWPerception::convertToCVMat(dwImageNvMedia *imageNvMedia, cv::Mat &cvimg)
if (imageNvMedia) {
// Read buffer to cvMat
NvMediaImageSurfaceMap surfaceMap;
memset(&surfaceMap, 0, sizeof(surfaceMap));
if(NvMediaImageLock(imageNvMedia->img, NVMEDIA_IMAGE_ACCESS_READ_WRITE, &surfaceMap)==NVMEDIA_STATUS_OK){
if(surfaceMap.surface[0].mapping == nullptr){
std::cout << "can not get NvMediaImage Surface \n";
return;
cvimg = OpenCVConnector::WriteToOpenCV(surfaceMap.surface[0].mapping, surfaceMap.width, surfaceMap.height);
//std::cout << "original img dims are: " << cvimg.rows << "," << cvimg.cols << std::endl;
NvMediaImageUnlock(imageNvMedia->img);
else{
std::cout << "img read fail \n" ;
and then i meet the problem is:
1.NvMediaImageLock function return NVMEDIA_STATUS_OK,but surfaceMap.surface[0].mapping == nullptr. Why?
Thank you!
Regards
Dear zhuweisheng,
You may use Imagestreamer to read data from one format to another. Please check the disccusion on the thread dwImageNvMedia dwImageStreamer dwImageCUDA - DriveWorks - NVIDIA Developer Forums to see if it helps.
Hi Steve, thank you for your reply,
I really want to know why in my function convertToCVMat, NvMediaImageLock return NVMEDIA_STATUS_OK but surfaceMap.surface[0].mapping in null ?
I have visited many disccusions about convert dwImageNvMedia to cv::Mat, and only this way is simple and clear.
so I want to fix the problem I meet and use this way.
the disccusion link you send I’ve already seen it,I’ve not found a good way to convert dwImageNvMedia to cv::Mat.
Thank you.
if (imageNvMedia) {
return;
else{
Dear zhuweisheng,
Could you please check the following link to see if it helps?
