I am trying to convert a dwImageNvMedia to cv::Mat. I first streamed a dwImageGL to dwImageNvMedia in RGBA format. Then I use NvMediaImageGetBits to get a pointer and put it into a cv::Mat.
Seems like I just get partial of the image and it keeps flashing. Could you please help me check how to accomplish this conversion?
Thanks in advaned!
dwImageHandle_t nextFrame = m_camera->readFrame();
if (nextFrame == nullptr) {
m_camera->resetCamera();
} else {
CHECK_DW_ERROR(dwImage_getCUDA(nextFrameCUDA, nextFrame));
CHECK_DW_ERROR(dwImage_copyConvert(m_imageRGBA, nextFrame, m_sdk));
dwImageHandle_t frameGL = m_streamerCUDA2GL->post(m_imageRGBA);
CHECK_DW_ERROR(dwImage_getGL(nextFrameGL, frameGL));
dwTime_t timeout = 1000;
// stream that image to the GL domain
CHECK_DW_ERROR(dwImageStreamer_producerSend(frameGL, m_streamer2NVM));
// receive the streamed image as a handle
dwImageHandle_t frameNVM;
CHECK_DW_ERROR(dwImageStreamer_consumerReceive(&frameNVM, timeout, m_streamer2NVM));
// get the specific image struct to be able to access texture ID and target
dwImageNvMedia* nextFrameNvMedia = nullptr;
CHECK_DW_ERROR(dwImage_getNvMedia(&nextFrameNvMedia, frameNVM));
NvMediaImageSurfaceMap surfaceMap;
void *pSrcBuff = NULL;
unsigned int srcPitch = 0;
unsigned int RGBABytesPerPixel = 2;
NvMediaStatus status;
NVM_SURF_FMT_DEFINE_ATTR(NVMSurfAttr);
if (NvMediaImageLock(nextFrameNvMedia->img, NVMEDIA_IMAGE_ACCESS_READ_WRITE, &surfaceMap) !=
NVMEDIA_STATUS_OK) {
std::cout << "NvMediaImageLock failed\n";
NvMediaSurfaceFormatGetAttrs(surfaceMap.type, NVMSurfAttr, surfaceMap.surfaces);
std::cout << "attribute properties : " << NVMSurfAttr[NVM_SURF_ATTR_SURF_TYPE].value << std::endl;
unsigned int NVMsrcImageSize = surfaceMap.height * surfaceMap.width * srcPitch * RGBABytesPerPixel;
//NVMsrcImageSize += nextFrameNvMedia->img->embeddedDataTopSize;
//NVMsrcImageSize += nextFrameNvMedia->img->embeddedDataBottomSize;
if (!(pSrcBuff = malloc(NVMsrcImageSize))) {
std::cout << "Out of memory\n";
status = NvMediaImageGetBits(nextFrameNvMedia->img, NULL, &pSrcBuff, &srcPitch);
if (status != NVMEDIA_STATUS_OK) {
std::cout << "NvMediaImageGetBits() failed\n";
m_cvimg = OpenCVConnector::WriteToOpenCV(pSrcBuff, surfaceMap.width, surfaceMap.height);
NvMediaImageUnlock(nextFrameNvMedia->img);
// returned the consumed image
CHECK_DW_ERROR(dwImageStreamer_consumerReturn(&frameNVM, m_streamer2NVM));
// notify the producer that the work is done
CHECK_DW_ERROR(dwImageStreamer_producerReturn(nullptr, timeout, m_streamer2NVM));
