A presentation in GTC2020 showed that it is possible to correlate SASS instructions to source code from within the Nsight Compute tool:
How do I do it?
Are there any additional steps if I am saving the report to a file and reading in another machine?
Thank you in advance!
You can refer to Nsight Compute :: Nsight Compute Documentation.
Basically, you need to compile your application with
-lineinfo
and have the source locally available. If your source is on a different machine, you need to mount or copy it. If copying, you might also need to disable the file properties (time stamp) checks in the options: Nsight Compute :: Nsight Compute Documentation.
I am using thrust and so I am referred to code in that library. Is there a way to see a call stack so I can back my way out to my code?
You can’t see any call stacks.
