Hi)I’a C# programmer. I use CUDA.NET library to make a programms in CUDA. I create a simple example of using CUDA. It’s OK. The kernel function is created by C language. I’d like to ask how to create an dinamic array in kenel function because a I have some errors during the compilation. I use MS VS 2008 Professional, Win 7 64bit, GeForce 610M, CUDA 5.0. For example,
global void func(float *g_date)
const int n = blockDim.x;
float *a = new float[n];
for(int i = 0; i < n; i++)
a[i] = (float)i;
delete[] a;
//make something with a and g_data
And my program crash during execution. Why? Is it a problem in CUDA.NET or CUDA generally doesn’t support it. I’d like to remember that the simple examples is working correctly with CUDA.NET. Please? help. If CUDA.NET don’t work correctly. Does any CUDA librarries exist which use a С#?
