how to create a dynamic array in the device function?
I have a C++ code like this:
void test(int n)
  double *da=new double[n];
  delete []da;
And if I want to execute the test() function in the device, like:
__device__ void test(int n)
  delete []da;
This is not working as expected, so I try another way, that also does not work:
void test(int n)
  double * da;
  cudaMalloc((void**)&da,n*sizeof(double));
  cudaFree(da);
So how to solve this problem?
There is no dynamic memory allocation permitted inside CUDA kernels.
As avidday said - no dynamic arrays. You can do dynamic shared memory allocation at kernel invocation. Failing that, just pass in a pointer to a global memory space the size you want.
As avidday said - no dynamic arrays. You can do dynamic shared memory allocation at kernel invocation. Failing that, just pass in a pointer to a global memory space the maximum size you want.
