how to deactivate built-in pull-up/-down resistor on GPIO
Hello nVidia,
As title said, the GPIO behave other then the GPIOs of a raspberry Pi here.I suppose this is caused by the built-in pull-up/-down resisotrs.
I would like to access these GPIOs through carrierboard’s 40-pol pinheader (J30)
Pin “MCLK05” (“gpio422”,pin number 7 of Expansion Header) is one of my choice used as input. through file system interface (/sys/class/gpio/gpio422/export) I can export this pin dynamically, change its direction and read its value without issue. But later I figured out it’s not as easy as a proper configured GPIO of a Raspberry pi to pull-down.
In one of my test, I’m using a external 1K Ohm pull-down resistor for this gpio,and its still too big for its purpose (875 Ohm works).
Later I discovered, with a MCU controlled MOSFET, I can not bring this pin to 3.3V (3.3V is selected through J514),but with the same setup I can toggle a GPIO from a pi.
I’m pretty sure there is no damage of the Xavier Devkit from very beginning. (ESD protected, J514 selected properly, Working voltage for GPIOs never go over 3.3V).So I would like to deactivate the built-in resistor firstly.
There are two possible ways to achive this:
Edit Xavier’s dtb file or edit memory block directely. I prefer the later one. But its still not clear how to calculate the memory address for this gpio, and what kind of value should I set.Counld someone give me some advice?
hello Gfast2,
had you tried to configure the GPIO via sysnode, you may refer to
Tegra Linux Driver Package TX2 Adaptation Guide for GPIO number calculation.
thanks
Thank you for your quick reply! We have now found the address 0x02430030:
Bank: 0 Reg: 0x02430030 Val: 0x0000005a -> soc_gpio42_pq6
(in /sys/kernel/debug/tegra_pinctrl_reg)
As Val is listed 0x0000005a.
Is that a bitmask?
How are those values calculated?
What do we need to change the value to so that the pullup/pulldown is deactivated?
It’s bitmap as below.
0x0000000002430030: PADCTL_CAM_SOC_GPIO42_0                                 = 0x00000474 //
          E_SCHMT                                                 = 0x00000000 // [12:12] DISABLE [DISABLE=0,ENABLE=1]
          GPIO_SF_SEL                                             = 0x00000001 // [10:10] SFIO [GPIO=0,SFIO=1]
          E_LPDR                                                  = 0x00000000 // [08:08] DISABLE [DISABLE=0,ENABLE=1]
          E_INPUT                                                 = 0x00000001 // [06:06] ENABLE [DISABLE=0,ENABLE=1]
          E_IO_HV                                                 = 0x00000001 // [05:05] ENABLE [DISABLE=0,ENABLE=1]
          TRISTATE                                                = 0x00000001 // [04:04] TRISTATE [PASSTHROUGH=0,TRISTATE=1]
          PUPD                                                    = 0x00000001 // [03:02] PULL_DOWN [NONE=0,PULL_DOWN=1,PULL_UP=2,RSVD=3]
          PM                                                      = 0x00000000 // [01:00] VGP3 [EXTPERIPH4=1,RSVD2=2,RSVD3=3,VGP3=0]
Thanks ShaneCCC,
I’ve successfully configured the value in those memory blocks according to your bit mask table. It’s pretty cool.
When I hange nothing on pin 7 from 40-pol pinheader (gpio422, MCLK05), I can read “1” from
cat /sys/class/gpio/gpio422/value
As default, “0x0000005a” is set for this pin. Acoording to your table, I figured out, the built-in Pull-Up resistor is activated. After I change this value to “0x00000478”
sudo busybox devmem 0x02430030 32 0x00000478
I cat read “0” from that file system address.
I think I know how to change Pull-Up/-Down Resistor now.
But I can still not toggle this GPIO with my own testbed. Which is controlled by a µM and GPIO is toggled by a MOSFET. But with a physical switch I can always switch this GPIO much more realiable.
Any tip for debugging/improving my Testbed?
Thanks a lot!
Su
To summarize, we want to configure MCLK05 resp. GPIO 422 of the Xavier so that it works just as the Raspberry Pi 3 GPIO 4 (same pin header position 7 on both Xavier and RPi3). What value do we need to write to 0x02430030 so that it is 100% compatible with RPi3?
I don’t know how the RPi3 working. However set it as default 0x5a should working as GPIO normally.
