Description
I have an ssd and I converted the pb file to uff,and the log goes like this:
2021-06-30 16:41:16.029792: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
Loading frozen_inference_graph.pb
WARNING:tensorflow:From /home/machine/.local/lib/python3.6/site-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py:274: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
NOTE: UFF has been tested with TensorFlow 1.15.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
UFF Version 0.6.9
=== Automatically deduced input nodes ===
[name: “Input”
op: “Placeholder”
input: “Cast”
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
dim {
dim {
dim {
dim {
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
WARNING:tensorflow:From /home/machine/.local/lib/python3.6/site-packages/uff/bin/../../uff/converters/tensorflow/converter.py:226: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: Cast yet.
Converting Cast as custom op: Cast
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_conf as custom op: FlattenConcat_TRT
Warning: No conversion function registered for layer: GridAnchor_TRT yet.
Converting GridAnchor as custom op: GridAnchor_TRT
Converting concat_box_loc as custom op: FlattenConcat_TRT
DEBUG [/home/machine/.local/lib/python3.6/site-packages/uff/bin/../../uff/converters/tensorflow/converter.py:143] Marking [‘NMS’] as outputs
No. nodes: 774
UFF Output written to frozen_inference_graph.uff
And then I run it with sampleUffSSD, and it goes wrong and say “Unsupported Operation _Cast”.
Now I wonder how it happened and how to make it correct. Thanks.
Environment
TensorRT 7: tensorRT 7.15
GPU Type:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
