Using output node pred_sbbox/concat_2
Using output node pred_mbbox/concat_2
Using output node pred_lbbox/concat_2
Converting to UFF graph
Warning: No conversion function registered for layer: Cast yet.
Converting pred_lbbox/Cast as custom op: Cast
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:179: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: Tile yet.
Converting pred_lbbox/Tile_2 as custom op: Tile
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 93, in <module>
main()
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 89, in main
debug_mode=args.debug
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 233, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 181, in from_tensorflow
debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 47, in convert_layer
return cls.registry_[op](name, tf_node, inputs, uff_graph, **kwargs)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter_functions.py", line 583, in convert_strided_slice
raise ValueError("new_axis_mask not supported")
ValueError: new_axis_mask not supported
