Hi, I have trained MASKRCNN on a custom dataset. I am not understanding how to deploy this trained model on Nvidia Jetson Nano.
Kindly help me with authentic sources.
Welcome to the NVIDIA Developer forums!. Your question belongs in the Jetson Nano Category. I will move it over for you.
Regards,
Tom K
May I know the model format of your Mask RCNN?
If it is trained with TensorFlow 1.15.x, we have an example to run it with TensorRT as below:
https://github.com/NVIDIA/TensorRT/tree/main/samples/sampleUffMaskRCNN
Thank you
I have used tensorflow==1.13.1.
Do you have a .pb format model from TensorFlow 1.x?
If yes, you should be able to run it with TensorRT with a similar flow as the tutorial: .pb - .uff - .trt
