I am very new to this and sorry if I am asking something extremely stupid.
So I was following this tutorial
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/deep-vision-header.jpg" width="100%">
<p align="right"><sup><a href="pytorch-collect.md">Back</a> | <a href="pytorch-collect-detection.md">Next</a> | </sup><a href="../README.md#hello-ai-world"><sup>Contents</sup></a>
<br/>
<sup>Transfer Learning - Object Detection</sup></s></p>
# Re-training SSD-Mobilenet
Next, we'll train our own SSD-Mobilenet object detection model using PyTorch and the [Open Images](https://storage.googleapis.com/openimages/web/visualizer/index.html?set=train&type=detection&c=%2Fm%2F06l9r) dataset. SSD-Mobilenet is a popular network architecture for realtime object detection on mobile and embedded devices that combines the [SSD-300](https://arxiv.org/abs/1512.02325) Single-Shot MultiBox Detector with a [Mobilenet](https://arxiv.org/abs/1704.04861) backbone.
<a href="https://arxiv.org/abs/1512.02325"><img src="https://github.com/dusty-nv/jetson-inference/raw/dev/docs/images/pytorch-ssd-mobilenet.jpg"></a>
In the example below, we'll train a custom detection model that locates 8 different varieties of fruit, although you are welcome to pick from any of the [600 classes](https://github.com/dusty-nv/pytorch-ssd/blob/master/open_images_classes.txt) in the Open Images dataset to train your model on. You can visually browse the dataset [here](https://storage.googleapis.com/openimages/web/visualizer/index.html?set=train&type=detection).
<img src="https://github.com/dusty-nv/jetson-inference/raw/dev/docs/images/pytorch-fruit.jpg">
To get started, first make sure that you have [JetPack 4.4](https://developer.nvidia.com/embedded/jetpack) or newer and [PyTorch installed](pytorch-transfer-learning.md#installing-pytorch) for **Python 3.6** on your Jetson. JetPack 4.4 includes TensorRT 7.1, which is the minimum TensorRT version that supports loading SSD-Mobilenet via ONNX. And the PyTorch training scripts used for training SSD-Mobilenet are for Python3, so PyTorch should be installed for Python 3.6.
## Setup
> **note:** first make sure that you have [JetPack 4.4](https://developer.nvidia.com/embedded/jetpack) or newer on your Jetson and [PyTorch installed](pytorch-transfer-learning.md#installing-pytorch) for **Python 3.6**
This file has been truncated. show original
and got a model for detecting fruits.
I thought it would also detect the default object like person, cow in this list
But it only detects fruits.
So are there ways to add more detectable object on top of a model?
Suppose you have run the retraining process.
When preparing the database with the below command:
$ python3 open_images_downloader.py --class-names "Apple,Orange,Banana,Strawberry,Grape,Pear,Pineapple,Watermelon" --data=data/fruit
It only downloads the fruit category (Apple, Orange, Banana, Strawberry, Grape, Pear, Pineapple, Watermelon ).
To train it with more classes, please expand the database with --class-names.
Thank you for your response!
What I want to ask is if it is possible to combine this fruit model and the default model that comes with ssdv2 which can already detect 90 objects, making it detect 100 or more objects.
It’s possible.
You will need to merge the database first and retrain a model with all the classes together.
system
Closed
September 19, 2021, 5:25am
7
