Dear Moderator, I tried this official sample, but at the step of " Model Conversion", I met an issue: KeyError: ‘UNKNOWN_SCALAR’ .
Here are the complete verbose logs and the issue repro model :
%run detectron2/tools/deploy/export_model.py \
--sample-image /home/nvidia/Downloads/Laparoscopic_Left_Hepatectomy/test/00000030_1344x1344.jpg \
--config-file output_onnx.yaml \
--export-method tracing \
--format onnx \
--output /home/nvidia/Downloads/output_onnx \
MODEL.WEIGHTS /home/nvidia/Downloads/output/model_final.pth \
MODEL.DEVICE cuda
[02/05 14:32:42 detectron2]: Command line arguments: Namespace(config_file='output_onnx.yaml', export_method='tracing', format='onnx', opts=['MODEL.WEIGHTS', '/home/nvidia/Downloads/output/model_final.pth', 'MODEL.DEVICE', 'cuda'], output='/home/nvidia/Downloads/output_onnx', run_eval=False, sample_image='/home/nvidia/Downloads/Laparoscopic_Left_Hepatectomy/test/00000030_1344x1344.jpg')
[W init.cpp:756] Warning: Use _jit_set_fusion_strategy, bailout depth is deprecated. Setting to (STATIC, 1) (function operator())
[02/05 14:32:45 d2.checkpoint.c2_model_loading]: Following weights matched with model:
| Names in Model | Names in Checkpoint | Shapes |
| backbone.bottom_up.res2.0.conv1.* | backbone.bottom_up.res2.0.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (64,) (64,) (64,) (64,) (64,64,1,1) |
| backbone.bottom_up.res2.0.conv2.* | backbone.bottom_up.res2.0.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (64,) (64,) (64,) (64,) (64,64,3,3) |
| backbone.bottom_up.res2.0.conv3.* | backbone.bottom_up.res2.0.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,64,1,1) |
| backbone.bottom_up.res2.0.shortcut.* | backbone.bottom_up.res2.0.shortcut.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,64,1,1) |
| backbone.bottom_up.res2.1.conv1.* | backbone.bottom_up.res2.1.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (64,) (64,) (64,) (64,) (64,256,1,1) |
| backbone.bottom_up.res2.1.conv2.* | backbone.bottom_up.res2.1.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (64,) (64,) (64,) (64,) (64,64,3,3) |
| backbone.bottom_up.res2.1.conv3.* | backbone.bottom_up.res2.1.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,64,1,1) |
| backbone.bottom_up.res2.2.conv1.* | backbone.bottom_up.res2.2.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (64,) (64,) (64,) (64,) (64,256,1,1) |
| backbone.bottom_up.res2.2.conv2.* | backbone.bottom_up.res2.2.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (64,) (64,) (64,) (64,) (64,64,3,3) |
| backbone.bottom_up.res2.2.conv3.* | backbone.bottom_up.res2.2.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,64,1,1) |
| backbone.bottom_up.res3.0.conv1.* | backbone.bottom_up.res3.0.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,256,1,1) |
| backbone.bottom_up.res3.0.conv2.* | backbone.bottom_up.res3.0.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,128,3,3) |
| backbone.bottom_up.res3.0.conv3.* | backbone.bottom_up.res3.0.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,128,1,1) |
| backbone.bottom_up.res3.0.shortcut.* | backbone.bottom_up.res3.0.shortcut.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,256,1,1) |
| backbone.bottom_up.res3.1.conv1.* | backbone.bottom_up.res3.1.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,512,1,1) |
| backbone.bottom_up.res3.1.conv2.* | backbone.bottom_up.res3.1.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,128,3,3) |
| backbone.bottom_up.res3.1.conv3.* | backbone.bottom_up.res3.1.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,128,1,1) |
| backbone.bottom_up.res3.2.conv1.* | backbone.bottom_up.res3.2.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,512,1,1) |
| backbone.bottom_up.res3.2.conv2.* | backbone.bottom_up.res3.2.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,128,3,3) |
| backbone.bottom_up.res3.2.conv3.* | backbone.bottom_up.res3.2.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,128,1,1) |
| backbone.bottom_up.res3.3.conv1.* | backbone.bottom_up.res3.3.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,512,1,1) |
| backbone.bottom_up.res3.3.conv2.* | backbone.bottom_up.res3.3.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (128,) (128,) (128,) (128,) (128,128,3,3) |
| backbone.bottom_up.res3.3.conv3.* | backbone.bottom_up.res3.3.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,128,1,1) |
| backbone.bottom_up.res4.0.conv1.* | backbone.bottom_up.res4.0.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,512,1,1) |
| backbone.bottom_up.res4.0.conv2.* | backbone.bottom_up.res4.0.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,256,3,3) |
| backbone.bottom_up.res4.0.conv3.* | backbone.bottom_up.res4.0.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (1024,) (1024,) (1024,) (1024,) (1024,256,1,1) |
| backbone.bottom_up.res4.0.shortcut.* | backbone.bottom_up.res4.0.shortcut.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (1024,) (1024,) (1024,) (1024,) (1024,512,1,1) |
| backbone.bottom_up.res4.1.conv1.* | backbone.bottom_up.res4.1.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,1024,1,1) |
| backbone.bottom_up.res4.1.conv2.* | backbone.bottom_up.res4.1.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,256,3,3) |
| backbone.bottom_up.res4.1.conv3.* | backbone.bottom_up.res4.1.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (1024,) (1024,) (1024,) (1024,) (1024,256,1,1) |
| backbone.bottom_up.res4.2.conv1.* | backbone.bottom_up.res4.2.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,1024,1,1) |
| backbone.bottom_up.res4.2.conv2.* | backbone.bottom_up.res4.2.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,256,3,3) |
| backbone.bottom_up.res4.2.conv3.* | backbone.bottom_up.res4.2.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (1024,) (1024,) (1024,) (1024,) (1024,256,1,1) |
| backbone.bottom_up.res4.3.conv1.* | backbone.bottom_up.res4.3.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,1024,1,1) |
| backbone.bottom_up.res4.3.conv2.* | backbone.bottom_up.res4.3.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,256,3,3) |
| backbone.bottom_up.res4.3.conv3.* | backbone.bottom_up.res4.3.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (1024,) (1024,) (1024,) (1024,) (1024,256,1,1) |
| backbone.bottom_up.res4.4.conv1.* | backbone.bottom_up.res4.4.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,1024,1,1) |
| backbone.bottom_up.res4.4.conv2.* | backbone.bottom_up.res4.4.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,256,3,3) |
| backbone.bottom_up.res4.4.conv3.* | backbone.bottom_up.res4.4.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (1024,) (1024,) (1024,) (1024,) (1024,256,1,1) |
| backbone.bottom_up.res4.5.conv1.* | backbone.bottom_up.res4.5.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,1024,1,1) |
| backbone.bottom_up.res4.5.conv2.* | backbone.bottom_up.res4.5.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (256,) (256,) (256,) (256,) (256,256,3,3) |
| backbone.bottom_up.res4.5.conv3.* | backbone.bottom_up.res4.5.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (1024,) (1024,) (1024,) (1024,) (1024,256,1,1) |
| backbone.bottom_up.res5.0.conv1.* | backbone.bottom_up.res5.0.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,1024,1,1) |
| backbone.bottom_up.res5.0.conv2.* | backbone.bottom_up.res5.0.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,512,3,3) |
| backbone.bottom_up.res5.0.conv3.* | backbone.bottom_up.res5.0.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (2048,) (2048,) (2048,) (2048,) (2048,512,1,1) |
| backbone.bottom_up.res5.0.shortcut.* | backbone.bottom_up.res5.0.shortcut.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (2048,) (2048,) (2048,) (2048,) (2048,1024,1,1) |
| backbone.bottom_up.res5.1.conv1.* | backbone.bottom_up.res5.1.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,2048,1,1) |
| backbone.bottom_up.res5.1.conv2.* | backbone.bottom_up.res5.1.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,512,3,3) |
| backbone.bottom_up.res5.1.conv3.* | backbone.bottom_up.res5.1.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (2048,) (2048,) (2048,) (2048,) (2048,512,1,1) |
| backbone.bottom_up.res5.2.conv1.* | backbone.bottom_up.res5.2.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,2048,1,1) |
| backbone.bottom_up.res5.2.conv2.* | backbone.bottom_up.res5.2.conv2.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (512,) (512,) (512,) (512,) (512,512,3,3) |
| backbone.bottom_up.res5.2.conv3.* | backbone.bottom_up.res5.2.conv3.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (2048,) (2048,) (2048,) (2048,) (2048,512,1,1) |
| backbone.bottom_up.stem.conv1.* | backbone.bottom_up.stem.conv1.{norm.bias,norm.running_mean,norm.running_var,norm.weight,weight} | (64,) (64,) (64,) (64,) (64,3,7,7) |
| backbone.fpn_lateral2.* | backbone.fpn_lateral2.{bias,weight} | (256,) (256,256,1,1) |
| backbone.fpn_lateral3.* | backbone.fpn_lateral3.{bias,weight} | (256,) (256,512,1,1) |
| backbone.fpn_lateral4.* | backbone.fpn_lateral4.{bias,weight} | (256,) (256,1024,1,1) |
| backbone.fpn_lateral5.* | backbone.fpn_lateral5.{bias,weight} | (256,) (256,2048,1,1) |
| backbone.fpn_output2.* | backbone.fpn_output2.{bias,weight} | (256,) (256,256,3,3) |
| backbone.fpn_output3.* | backbone.fpn_output3.{bias,weight} | (256,) (256,256,3,3) |
| backbone.fpn_output4.* | backbone.fpn_output4.{bias,weight} | (256,) (256,256,3,3) |
| backbone.fpn_output5.* | backbone.fpn_output5.{bias,weight} | (256,) (256,256,3,3) |
| proposal_generator.rpn_head.anchor_deltas.* | proposal_generator.rpn_head.anchor_deltas.{bias,weight} | (12,) (12,256,1,1) |
| proposal_generator.rpn_head.conv.* | proposal_generator.rpn_head.conv.{bias,weight} | (256,) (256,256,3,3) |
| proposal_generator.rpn_head.objectness_logits.* | proposal_generator.rpn_head.objectness_logits.{bias,weight} | (3,) (3,256,1,1) |
| roi_heads.box_head.fc1.* | roi_heads.box_head.fc1.{bias,weight} | (1024,) (1024,12544) |
| roi_heads.box_head.fc2.* | roi_heads.box_head.fc2.{bias,weight} | (1024,) (1024,1024) |
| roi_heads.box_predictor.bbox_pred.* | roi_heads.box_predictor.bbox_pred.{bias,weight} | (4,) (4,1024) |
| roi_heads.box_predictor.cls_score.* | roi_heads.box_predictor.cls_score.{bias,weight} | (2,) (2,1024) |
| roi_heads.mask_head.deconv.* | roi_heads.mask_head.deconv.{bias,weight} | (256,) (256,256,2,2) |
| roi_heads.mask_head.mask_fcn1.* | roi_heads.mask_head.mask_fcn1.{bias,weight} | (256,) (256,256,3,3) |
| roi_heads.mask_head.mask_fcn2.* | roi_heads.mask_head.mask_fcn2.{bias,weight} | (256,) (256,256,3,3) |
| roi_heads.mask_head.mask_fcn3.* | roi_heads.mask_head.mask_fcn3.{bias,weight} | (256,) (256,256,3,3) |
| roi_heads.mask_head.mask_fcn4.* | roi_heads.mask_head.mask_fcn4.{bias,weight} | (256,) (256,256,3,3) |
| roi_heads.mask_head.predictor.* | roi_heads.mask_head.predictor.{bias,weight} | (1,) (1,256,1,1) |
/home/nvidia/Downloads/detectron2/detectron2/structures/image_list.py:85: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
assert t.shape[:-2] == tensors[0].shape[:-2], t.shape
/home/nvidia/Downloads/detectron2/detectron2/structures/boxes.py:155: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
assert tensor.dim() == 2 and tensor.size(-1) == 4, tensor.size()
/home/nvidia/Downloads/detectron2/detectron2/modeling/proposal_generator/proposal_utils.py:106: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
if not valid_mask.all():
/home/nvidia/Downloads/detectron2/detectron2/structures/boxes.py:191: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
assert torch.isfinite(self.tensor).all(), "Box tensor contains infinite or NaN!"
/home/nvidia/Downloads/detectron2/detectron2/structures/boxes.py:192: TracerWarning: Iterating over a tensor might cause the trace to be incorrect. Passing a tensor of different shape won't change the number of iterations executed (and might lead to errors or silently give incorrect results).
h, w = box_size
/home/nvidia/Downloads/detectron2/detectron2/layers/nms.py:15: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
assert boxes.shape[-1] == 4
/home/nvidia/.local/lib/python3.8/site-packages/torch/__init__.py:772: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
assert condition, message
/home/nvidia/Downloads/detectron2/detectron2/layers/roi_align.py:55: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
assert rois.dim() == 2 and rois.size(1) == 5
/home/nvidia/Downloads/detectron2/detectron2/modeling/roi_heads/fast_rcnn.py:138: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
/home/nvidia/Downloads/detectron2/detectron2/modeling/roi_heads/fast_rcnn.py:143: UserWarning: __floordiv__ is deprecated, and its behavior will change in a future version of pytorch. It currently rounds toward 0 (like the 'trunc' function NOT 'floor'). This results in incorrect rounding for negative values. To keep the current behavior, use torch.div(a, b, rounding_mode='trunc'), or for actual floor division, use torch.div(a, b, rounding_mode='floor').
num_bbox_reg_classes = boxes.shape[1] // 4
h, w = box_size
/home/nvidia/Downloads/detectron2/detectron2/modeling/roi_heads/fast_rcnn.py:155: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
if num_bbox_reg_classes == 1:
/home/nvidia/Downloads/detectron2/detectron2/modeling/roi_heads/mask_head.py:139: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
if cls_agnostic_mask:
KeyError Traceback (most recent call last)
File ~/Downloads/detectron2/tools/deploy/export_model.py:228
226 elif args.export_method == "tracing":
227 sample_inputs = get_sample_inputs(args)
--> 228 exported_model = export_tracing(torch_model, sample_inputs)
230 # run evaluation with the converted model
231 if args.run_eval:
File ~/Downloads/detectron2/tools/deploy/export_model.py:132, in export_tracing(torch_model, inputs)
130 elif args.format == "onnx":
131 with PathManager.open(os.path.join(args.output, "model.onnx"), "wb") as f:
--> 132 torch.onnx.export(traceable_model, (image,), f, opset_version=STABLE_ONNX_OPSET_VERSION)
133 logger.info("Inputs schema: " + str(traceable_model.inputs_schema))
134 logger.info("Outputs schema: " + str(traceable_model.outputs_schema))
File ~/.local/lib/python3.8/site-packages/torch/onnx/__init__.py:305, in export(model, args, f, export_params, verbose, training, input_names, output_names, operator_export_type, opset_version, do_constant_folding, dynamic_axes, keep_initializers_as_inputs, custom_opsets, export_modules_as_functions)
39 r"""
40 Exports a model into ONNX format. If ``model`` is not a
41 :class:`torch.jit.ScriptModule` nor a :class:`torch.jit.ScriptFunction`, this runs
301 model to the file ``f`` even if this is raised.
302 """
304 from torch.onnx import utils
--> 305 return utils.export(model, args, f, export_params, verbose, training,
306 input_names, output_names, operator_export_type, opset_version,
307 do_constant_folding, dynamic_axes,
308 keep_initializers_as_inputs, custom_opsets,
309 export_modules_as_functions)
File ~/.local/lib/python3.8/site-packages/torch/onnx/utils.py:118, in export(model, args, f, export_params, verbose, training, input_names, output_names, operator_export_type, opset_version, do_constant_folding, dynamic_axes, keep_initializers_as_inputs, custom_opsets, export_modules_as_functions)
115 else:
116 operator_export_type = OperatorExportTypes.ONNX
--> 118 _export(model, args, f, export_params, verbose, training, input_names, output_names,
119 operator_export_type=operator_export_type, opset_version=opset_version,
120 do_constant_folding=do_constant_folding, dynamic_axes=dynamic_axes,
121 keep_initializers_as_inputs=keep_initializers_as_inputs,
122 custom_opsets=custom_opsets, export_modules_as_functions=export_modules_as_functions)
File ~/.local/lib/python3.8/site-packages/torch/onnx/utils.py:719, in _export(model, args, f, export_params, verbose, training, input_names, output_names, operator_export_type, export_type, opset_version, do_constant_folding, dynamic_axes, keep_initializers_as_inputs, fixed_batch_size, custom_opsets, add_node_names, onnx_shape_inference, export_modules_as_functions)
715 dynamic_axes = {}
716 _validate_dynamic_axes(dynamic_axes, model, input_names, output_names)
718 graph, params_dict, torch_out = \
--> 719 _model_to_graph(model, args, verbose, input_names,
720 output_names, operator_export_type,
721 val_do_constant_folding,
722 fixed_batch_size=fixed_batch_size,
723 training=training,
724 dynamic_axes=dynamic_axes)
726 # TODO: Don't allocate a in-memory string for the protobuf
727 defer_weight_export = export_type is not ExportTypes.PROTOBUF_FILE
File ~/.local/lib/python3.8/site-packages/torch/onnx/utils.py:503, in _model_to_graph(model, args, verbose, input_names, output_names, operator_export_type, do_constant_folding, _disable_torch_constant_prop, fixed_batch_size, training, dynamic_axes)
499 graph, params, torch_out, module = _create_jit_graph(model, args)
501 params_dict = _get_named_param_dict(graph, params)
--> 503 graph = _optimize_graph(graph, operator_export_type,
504 _disable_torch_constant_prop=_disable_torch_constant_prop,
505 fixed_batch_size=fixed_batch_size, params_dict=params_dict,
506 dynamic_axes=dynamic_axes, input_names=input_names,
507 module=module)
508 from torch.onnx.symbolic_helper import _onnx_shape_inference
509 if isinstance(model, torch.jit.ScriptModule) or isinstance(model, torch.jit.ScriptFunction):
File ~/.local/lib/python3.8/site-packages/torch/onnx/utils.py:232, in _optimize_graph(graph, operator_export_type, _disable_torch_constant_prop, fixed_batch_size, params_dict, dynamic_axes, input_names, module)
230 torch._C._jit_pass_onnx_set_dynamic_input_shape(graph, dynamic_axes, input_names)
231 torch._C._jit_pass_onnx_lint(graph)
--> 232 graph = torch._C._jit_pass_onnx(graph, operator_export_type)
233 torch._C._jit_pass_onnx_lint(graph)
234 torch._C._jit_pass_lint(graph)
File ~/.local/lib/python3.8/site-packages/torch/onnx/__init__.py:354, in _run_symbolic_function(*args, **kwargs)
352 def _run_symbolic_function(*args, **kwargs):
353 from torch.onnx import utils
--> 354 return utils._run_symbolic_function(*args, **kwargs)
File ~/.local/lib/python3.8/site-packages/torch/onnx/utils.py:1061, in _run_symbolic_function(g, block, n, inputs, env, operator_export_type)
1059 return None
1060 attrs = {k: n[k] for k in n.attributeNames()}
-> 1061 return symbolic_fn(g, *inputs, **attrs)
1063 elif ns == "prim":
1064 if op_name == "Constant" and not n.mustBeNone():
File ~/.local/lib/python3.8/site-packages/torch/onnx/symbolic_opset9.py:2065, in to(g, self, *args)
2062 if sym_help._is_value(dtype) or isinstance(dtype, torch.Tensor):
2063 # aten::to(Tensor, Tensor, bool, bool, memory_format)
2064 dtype = args[0].type().scalarType()
-> 2065 return g.op("Cast", self, to_i=sym_help.cast_pytorch_to_onnx[dtype])
2066 else:
2067 # aten::to(Tensor, ScalarType, bool, bool, memory_format)
2068 # memory_format is ignored
2069 return g.op("Cast", self, to_i=sym_help.scalar_type_to_onnx[dtype])
KeyError: 'UNKNOWN_SCALAR'
I searched this bug on internet and try to figure it out, but still can’t find a solution, please help me !
