How to disable headless mode without remote access
I enabled headless mode using the following command: sudo systemctl set-default multi-user.target to use my AGX Orin Developer Kit remotely via nomachine but nomachine doesn’t recognize the machine. I’ve tried alt+ctl+F3 (and tried every f key) but can’t get into the terminal to run ‘sudo systemctl set-default graphical.target’ to turn off headless mode. I can get into the debug console via putty using my PC but that cosole is very limited and doesn’t let me use ‘sudo systemctl set-default graphical.target’. How to turn off headless mode from the debug console? Or is it possible to do it via recovery mode? Or is my only hope to reflash the machine (I pray it isn’t). Can someone please give me some guidance.
There is a supported use-case in developer guide. Please check:
Orin specific Display Configuration — NVIDIA Jetson Linux Developer Guide 1 documentation
Please use 6.0GA and give it a try.
