My L4t info:
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
In my project i use a 120D camera,after capture the image, i use OpenCv to do the fisheye correction.
My question is: can i do this correction with MutiMedia api, argus api?
I haven’t find any samples, can anyone give me some help, thanks !
We have the functions in VPI. Please check the document and see if you can apply it to your use-case:
VPI - Vision Programming Interface: Lens Distortion Correction
Ok, i will make a try, thanks !
And does VPI make better performance than cv::fisheye::projectPoints ?
Hi
Support cv::fisheye::projectPoints use CPU for calculation.
But VPI can use CPU/GPU/VIC for acceleration.
You can find the performance table (for the remap algorithm) below:
https://docs.nvidia.com/vpi/2.4/algo_remap.html#algo_remap_perf
system
Closed
9
