How to enable PPS on Jetson Orin Nano?
Dear Forum Members,
I would like to use the PPS signal from the u-blox Z9P based module but I haven’t known which GPIO on the Nvidia Jetson Orin Nano Devkit should I connect to and how to configure it in the kernel/device-tree. Could you give me some hint, please ?
Thanks in advance and best regards,
Khang
Please check below topics to see if can help:
Adding PPS on Jetson Orin with Pin 31 - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
How to Enable PPS on Orin which pin to setup - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
