How to enable remote desktop sharing
I want to enable remote desktop with desktop sharing, “settings–>system–>remote desktop–>desktop sharing“
but it can not work with port is empty and can not set port with gray window
There should be a port number there by default. Can’t change it though. Are you trying to connect locally? Have you tried NVIDIA Sync?
thanks,it was solved after update system.
i understand this port cant change and should be default. but normally it will display as 3390 or listen on 3390 via “ss -alntp“ .
