1: Our custom board connect Intel I211AT NIC in PCIE1, as follow:
2: In Jetpack4.4 for xavier nx, at first enable controller #4 and #5, and then modify devicetree:
pcie@14160000 {
status = “okay”;
nvidia,pex-wake = <&tegra_main_gpio TEGRA194_MAIN_GPIO(L, 2)
GPIO_ACTIVE_HIGH>;
vddio-pex-ctl-supply = <&p3668_spmic_sd3>;
nvidia,disable-aspm-states = <0xf>;
//nvidia,enable-power-down;
nvidia,max-speed = <3>;
num-lanes = <0>;
phys = <&p2u_11>;
phy-names = "pcie-p2u-0";
3: lspci:
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad1 (rev a1) 0004:01:00.0 Ethernet controller: Intel Corporation Device 1532 (rev 03) 0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1)
dmesg | grep igb:
[ 1.553592] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.553597] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.553641] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.553646] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
4: I had make install igb-5.3.5.39 driver.
But ifconfig only see eth0 interface.
Does Jetpack4.4 support intel I211AT NIC by default?
What should I do ? Thanks very much.
