Does Jetpack 4.62 and eMMC 8g versions of Jetson Xavier NX support spi?
After connecting the display screen, I open the terminal and try the following commands:
sudo /opt/nvidia/jetson-io/jetson-io.py
But the interface flashes back, so enter the following command
sudo /opt/nvidia/jetson-io/config-by-pin. py | less
sudo /opt/nvidia/jetson-io/jetson-io. py | less
Error: No DTB found for NVIDIA Jetson Xavier NX Developer Kit!
But I found this file in the boot/dtb folder: kernel_ tegra194-p3668-all-p3509-0000.dtb
At the same time, I tried the following two instructions:
cat /sys/firmware/devicetree/base/compatible
fdtget /boot/dtb/kernel_ tegra194-p3668-all-p3509-0000.dtb / compatible
The returned results are the same:
nvidia,p3449-0000+p3668-0000nvidia,p3449-0000+p3668-0001nvidia,p3509-0000+p3668-0000nvidia,p3509-0000+p3668-0001nvidia,tegra194
Can someone tell me how to open the SPI?
