Hi DaneLLL,
Thank you for replying. I’ve been trying to modify the device tree similar to what we found in the following post.
Our modifications are as follows.
1. under ucsi_ccg
ucsi_ccg: ucsi_ccg@8 {
- status = "okay";
+ status = "disabled";
2. under xusb_padctl@3520000, made sure mode is set to "host" and usb3 ports need its companion usb2 port.
xusb_padctl: xusb_padctl@3520000 {
ports {
usb2-3 {
mode = "host";
status = "okay";
usb3-3 {
status = "okay";
nvidia,usb2-companion = <0x03>;
usb3-gen1-only = <0x01>
3. Removed all "extcon*" property under xhci@3610000 and xudc@3550000.
We could compile the dts file to a dtb file. However, I am not sure how to use dd or flash.sh so that our modified dtb is applied.
