How to enable Wi-Fi and BT on the TX2.
Hi All,
I want to know how to enable Wi-Fi and BT on the TX2.
Wi-Fi and Blue-Tooth are looks like not working well.
Please give me your help.
Thanks & Best Regards,
Hi nwlee,
The default Wi-Fi is enabled on TX2.
Are you want to enable Wi-Fi or Wi-Fi AP mode?
The BT you can enable from: System Settings -> Bluetooth -> Turn on Bluetooth.
If you want to use Wi-Fi AP mode you may use the hotspot as defined: https://askubuntu.com/questions/180733/how-to-setup-an-access-point-mode-wi-fi-hotspot.
Otherwise you may execute
rfkill list
to see additional info.
0: bluedroid_pm: Bluetooth
	Soft blocked: yes
	Hard blocked: no
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
2: brcmfmac-wifi: Wireless LAN
	Soft blocked: no
	Hard blocked: no
Reference: https://devtalk.nvidia.com/default/topic/1028351/how-to-disable-wifi-and-bluetooth-radios-in-tx2-module-/?offset=6.
