Greetings,
I have a 16G-EMMC NX with Jetpack4.5 working on our carrier board,which connect to NX SDMMC3_HV (3.3V Capable), and I can’t find the mmc info when system power up.
Do I need modify kernel & dts code to enable sdmmc3?
the dts log is as follows
sdhci@3440000 {
cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Y, 4) 0>;
// nvidia,cd-wakeup-capable;
vmmc-supply = <&p3668_vdd_sdmmc1_sw>;
vqmmc-supply = <&p3668_spmic_sd3>;
uhs-mask = <0x0>;
tap-delay = <3>;
// no-sdio;
// no-mmc;
// /delete-property/ nvidia,min-tap-delay;
// /delete-property/ nvidia,max-tap-delay;
// /delete-property/ mmc-hs200-1_8v;
mmc-hs400-1_8v;
mmc-hs400-1_8v;
mmc-hs400-enhanced-strobe;
/delete-property/ cd-gpios;
/delete-property/ cd-inverted;
/delete-property/ pinctrl-0;
/delete-property/ pinctrl-1;
/delete-property/ pinctrl-names;
non-removable;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-ocr-mask = <3>;
uhs-mask = <0x0>;
max-clk-limit = <400000>;
tap-delay = <3>;
// vmmc-supply = <&p3668_vdd_sdmmc1_sw>;
status = "okay";
