Hello, I’m trying to flash my Jetson Orin NX (p3509-a02+p3767-0000) using Ubuntu Base rootfs (ubuntu-base-20.04.5-base-arm64.tar.gz) that I got from Ubuntu instead of the sample rootfs provided as the size is too big and I would like to have GUI components where I didn’t pick the minimal flavors Nvidia provides. My goal is to generate a massflash package that is the smallest possible size. To reduce the size, I decided to use another rootfs. I’m using the Linux_for_Tegra from jetson_linux_r35.4.1_aarch64.tbz2. So far, I’m having trouble. I’m not sure, it could be that I need some programs in the rootfs that are missing or I need a Linux kernel that’s not included anymore from switching rootfs. Any help in resolving this is appreciated. Thank you for your time.
sudo ./apply_binaries.sh
Pre-installing… skip compatibility checking.
Unpacking nvidia-l4t-core (35.4.1-20230801124926) …
dpkg: dependency problems prevent configuration of nvidia-l4t-core:
nvidia-l4t-core depends on libegl1; however:
Package libegl1 is not installed.
nvidia-l4t-core depends on libexpat1; however:
Package libexpat1 is not installed.
dpkg: error processing package nvidia-l4t-core (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
nvidia-l4t-core
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 --no-flash --massflash 1 p3509-a02+p3767-0000 internal
gzip: /home/rand/Flash_orn/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.120-tegra
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/sbin/mtd_debug’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/sbin/mtd_debug /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/mtd_debug
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libwrap.so.0’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libwrap.so.0 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libwrap.so.0
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libcap.so.2’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libcap.so.2 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libcap.so.2
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libmnl.so.0’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libmnl.so.0 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libmnl.so.0
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libdbus-1.so.3’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libdbus-1.so.3 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libdbus-1.so.3
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libreadline.so.8’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libreadline.so.8 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libreadline.so.8
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libdevmapper.so.1.02.1’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/aarch64-linux-gnu/libdevmapper.so.1.02.1 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libdevmapper.so.1.02.1
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libssl.so.1.1’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libssl.so.1.1 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/libssl.so.1.1
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libgssapi_krb5.so.2’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libgssapi_krb5.so.2 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libgssapi_krb5.so.2
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libkrb5.so.3’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libkrb5.so.3 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libkrb5.so.3
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libk5crypto.so.3’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libk5crypto.so.3 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libk5crypto.so.3
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libkrb5support.so.0’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libkrb5support.so.0 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libkrb5support.so.0
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libcrypto.so.1.1’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libcrypto.so.1.1 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libcrypto.so.1.1
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libelf.so.1’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libelf.so.1 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libelf.so.1
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libbsd.so.0’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libbsd.so.0 /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libbsd.so.0
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtd.ko’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtd.ko /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtd.ko
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtdblock.ko’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtdblock.ko /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtdblock.ko
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtd_blkdevs.ko’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtd_blkdevs.ko /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.120-tegra/kernel/drivers/mtd/mtd_blkdevs.ko
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.120-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/lib/modules/5.10.120-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.120-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/modules/5.10.120-tegra/kernel/drivers/net/ethernet/realtek/r8168.ko’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/lib/modules/5.10.120-tegra/kernel/drivers/net/ethernet/realtek/r8168.ko /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.10.120-tegra/kernel/drivers/net/ethernet/realtek/r8168.ko
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/etc/ssh/sshd_config’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/etc/ssh/sshd_config /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//etc/ssh/sshd_config
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/sbin/sshd’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/sbin/sshd /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/sshd
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/bin/ping’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/bin/ping /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/ping
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/sbin/dhclient-script’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/sbin/dhclient-script /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//sbin/dhclient-script
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/bin/ip’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/bin/ip /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/ip
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/bin/scp’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/bin/scp /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/scp
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/bin/xxd’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/usr/bin/xxd /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/xxd
cp: cannot stat ‘/home/rand/Flash_orn/Linux_for_Tegra/rootfs/bin/kmod’: No such file or directory
warning: cp -f /home/rand/Flash_orn/Linux_for_Tegra/rootfs/bin/kmod /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/kmod
sed: can’t read /home/rand/Flash_orn/Linux_for_Tegra/bootloader/ramdisk_tmp//etc/ssh/sshd_config: No such file or directory
command is failed
Error: /home/rand/Flash_orn/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/rand/Flash_orn/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up…
