I’m trying to flash my Jetson Orin NX, but I’m facing an issue.
For context, I’m using WSL2, Ubuntu 20.04. I’ve followed these tutorials step-by-step:
https://docs.nvidia.com/sdk-manager/wsl-systems/index.html#wsl-systems-flash-jetson
However, when I executed the line below, I got some errors.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1 --network usb0 --showlogs
At first, the output showed:
cat: /sys/module/usbcore/parameters/autosuspend: No such file or directory
./tools/kernel_flash/l4t_initrd_flash.sh: line 43: remove_udev_rules: command not found
So, following the answers in this post (Seeed J3011/J401 Orin Nano flashing fails - line 43: remove_udev_rules: command not found), I removed all the lines related to “autosuspend” in the l4t_initrd_flash.sh file.
After that, I executed “sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1 --network usb0 --showlogs” again and when the process gets to step 3 (Start the flashing process) the output is:
Waiting for target to boot-up…
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up…
The complete output is:
/home/laura/Downloads/mfi_recomputer-orin-j401/recomputer-orin-j401.conf: line 29: /home/laura/Downloads/mfi_recomputer-orin-j401/p3768-0000-p3767-0000-a0.conf: No such file or directory
/home/laura/Downloads/mfi_recomputer-orin-j401/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-1 --device-instance 0 --flash-only --external-device nvme0n1p1 -c “tools/kernel_flash/flash_l4t_nvme.xml” -S 80GiB --network usb0 recomputer-orin-j401 external
Entry added by NVIDIA initrd flash tool
/home/laura/Downloads/mfi_recomputer-orin-j401/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
* - Step 1: Build the flashing environment *
Create flash environment 0
/home/laura/Downloads/mfi_recomputer-orin-j401/bootloader /home/laura/Downloads/mfi_recomputer-orin-j401
Finish creating flash environment 0.
* - Step 2: Boot the device with flash initrd image *
/home/laura/Downloads/mfi_recomputer-orin-j401/temp_initrdflash/bootloader0 /home/laura/Downloads/mfi_recomputer-orin-j401
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-j401-p3768-0000+p3767-0000-recomputer.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “rcmboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-j401-p3768-0000+p3767-0000-recomputer.dtb” --bct_backup --instance 1-1
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0731 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0731 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0731 ] rcm boot with presigned binaries
[ 0.0742 ] tegrarcm_v2 --instance 1-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0749 ] BR_CID: 0x80012344705DD7811C0000000A010040
[ 0.0770 ] Sending bct_br
[ 0.0774 ] Sending mb1
[ 0.0799 ] Sending psc_bl1
[ 0.0984 ] Sending bct_mb1
[ 0.1082 ] Generating blob for T23x
[ 0.1100 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.1107 ] The number of images in blob is 19
[ 0.1108 ] blobsize is 107839651
[ 0.1108 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3592256
[ 0.1358 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.1362 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.1364 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.1365 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[ 0.1366 ] Not supported type: mb2_applet
[ 0.1367 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[ 0.1370 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1371 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.1384 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12065552
[ 0.1425 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1441 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1446 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 383232
[ 0.1449 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.1451 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414976
[ 0.1453 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1454 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[ 0.1460 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1463 ] Added binary blob_boot0.img of size 83722240
[ 0.1944 ] Added binary blob_tegra234-j401-p3768-0000+p3767-0000-recomputer.dtb of size 244259
[ 0.2710 ] tegrarcm_v2 --instance 1-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2718 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[ 0.3720 ] Sending bct_mem
[ 0.3726 ] Sending blob
[ 7.3461 ] RCM-boot started
* - Step 3: Start the flashing process *
Timeout
Cleaning up…
Thank you so much in advance.
