I am trying to clone the entire NVMe ssd on one Jetson Nx to another Jetson Nx (same)
I found this and actually trying to do the same to NVMe:How to Flash clone image to external device in the XavierNX environment
I want to clone the App partition in NVMeSSD, so I executed the following on the xaviernx board to create a clone image file.
img2simg /dev/nvme0n1p1 system.img.ext
Relying on the above URL description, we replaced system.img by system.img.ext on my pc
cp system.img.ext tools/kernel_flash/images/external/system.img
and adding
sha1sum system.img > system.img.sha1sum
and l4t_initrd_flash.sh with --flash-only option.
sudo NO_ROOTFS=0 ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --showlogs jetson-xavier-nx-devkit-qspi internal
As a result, the following error occurred.
error: file_write: write: No space left on device
Cannot write output file
[ 467]: l4t_flash_from_kernel: Error flashing external device
[ 467]: l4t_flash_from_kernel: nvsimg2img …Linux_for_Tegra/tools/kernel_flash/images/external/system.img /dev/sde failed
[ 467]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
We have M.2 250GB NVMeSSD.
sudo blockdev --getsize64 /dev/nvme0n1p1
The above size is 249542213632
Backup img is root on nvme
flash_l4t_external.xml (8.5 KB)
flash_l4t_external.xml is here
