I’m trying to make a system image from orin nx external nvme (nvidia_sdk folder version: Jetson_Linux_R35.2.1_aarch64).
Although I’m able to make this image, I’m unable to flash it back into external nvme. It seems like, that the image is being flashed, but it always ends with this error (after a few minutes): error: file_write: write: No space left on device.
Snippet from flash log (full flash log in the attachment):
Copied 16896 bytes from /mnt/internal/gpt_secondary_3_0.bin to address 0x03ffbe00 in flash
[ 414]: l4t_flash_from_kernel: Successfully flash the qspi
Cannot write output file
[ 588]: l4t_flash_from_kernel: /mnt/simg2img /mnt/external/system.img /dev/nvme0n1p1 failed
[ 588]: l4t_flash_from_kernel: Error flashing external device
Flash failure
Cleaning up...
My steps for creating an image and flashing back into the device are as follows:
- Create image with this command:
sudo img2simg /dev/nvme0n1p1 system.img.ext(no problem) - Copy created image into
../Linux_for_Tegra/tools/kernel_flash/images/externaland rename it tosystem.img.(no problem) - Sign the image and update system.img.sha1sum. (no problem)
- Try to flash with: (this fails)
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external_custom.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3509-a02+p3767-0000 internal
Is this workflow wrong?
Thank you for you help.
flash_1-2_0_20230310-145503.log (81.6 KB)
Some additional notes:
Tried to specify APP partition size with -S, it didn’t help.
I’m able to flash the orin nx and external nvme with this command without any issues:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external_custom.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3509-a02+p3767-0000 internal
flash_l4t_external_custom.xml → this document has only first num_sectors parameter modified, according to used nvme
