• Hardware Platform (Jetson / GPU) - Jetson Nano • DeepStream Version - 6.0.1 • JetPack Version (valid for Jetson only) - 4.6.1 • TensorRT Version - 8.2 • NVIDIA GPU Driver Version (valid for GPU only) - 10.2 • Issue Type( questions, new requirements, bugs)
How to get a filename of smart recorded videos in python?
I need to upload the stored videos to s3 bucket, so I need filename of recorded video.
currently the whole filename is generated by low level. only smart-rec-file-prefix
parameter is open. for example, Smart_Record_00000_20231102-022215_9426.mp4.
currently there is no interface to get the full file name. here a workaround. you can use smart-rec-dir-path property to set recording directory. then loop the files in the directory to get the full file name.
