we set the plugin “nvdsosd”
gst_pad_add_probe(osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER, callback_osd, data, NULL), where the “osd_sink_pad” is the sink pad of plugin “nvdsosd”, and we want to get the results of classification of sgie in the function callback_osd.
Could you share your setup?
Thanks for your reply!
I just used the deestream 4.0 example “deepstream_sdk_v4.0.1_x86_64/sources/apps/sample_apps/deepstream-test2”,
in the probe function
“static GstPadProbeReturn osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)”,
i added the following code to show the classification result of sgie:
for (l = obj_meta->classifier_meta_list; l != NULL; l = l->next) {
NvDsClassifierMeta* classifierMeta = (NvDsClassifierMeta*) (l->data);
for (n = classifierMeta->label_info_list; n != NULL; n = n->next) {
NvDsLabelInfo* labelInfo = (NvDsLabelInfo*) (n->data);
std::cout << result_label << ": " << result_prob << std::endl;
however, there was nothing printed with car object detected.
We can see result_label printed after applying the patch:
diff --git a/apps/deepstream/sample_apps/deepstream-test2/deepstream_test2_app.c b/apps/deepstream/sample_apps/deepstream-test2/deepstream_test2_app.c
index 5c16dca..79c3e0c 100644
--- a/apps/deepstream/sample_apps/deepstream-test2/deepstream_test2_app.c
+++ b/apps/deepstream/sample_apps/deepstream-test2/deepstream_test2_app.c
@@ -109,6 +109,18 @@ osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
+ NvDsMetaList * l = NULL;
+ NvDsMetaList * n = NULL;
+ for (l = obj_meta->classifier_meta_list; l != NULL; l = l->next)
+ NvDsClassifierMeta* classifierMeta = (NvDsClassifierMeta*) (l->data);
+ for (n = classifierMeta->label_info_list; n != NULL; n = n->next)
+ NvDsLabelInfo* labelInfo = (NvDsLabelInfo*) (n->data);
+ g_print("[%d] label: %s \n ", vehicle_count, &labelInfo->result_label[0]);
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
FYR.
Hi, DaneLLL, thanks for your reply!
We did what you showed in the osd_sink_pad_buffer_probe, and when the sgie of single label classifier used, everything work fine, however the sgie in our procedure is a multi label classifier, the head node of classifierMeta->label_info_list is always null.
we showed the config file of the sgie in this topic:
could you give me some advices, thank you!
For clearness, please continue in the new created topic:
