Hello there!
There is a HDMI to CSI-2 adapter board that I bought from Geekworm. It uses TC358743 IC. As far as I know L4T 35.4.1 version has driver support about that IC. But there is no device tree configuration about the driver. So, I’ve looked the Sensor Programming Guide. There is a tutorial for Device Registration. But I’ve got some questions.
At the “To register a device using the main platform device tree file” section, there should be a tegra194-p2888-0001-p2822-0000.dtsi file. But there is only a .dts file exist with that name and it doesn’t contain “include “tegra194-camera-plugin-manager.dtsi”” line. The source file looks like this:
tegra194-p2888-0001-p2822-0000.dts file:
* Copyright (c) 2017-2022, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify it
* under the terms and conditions of the GNU General Public License,
* version 2, as published by the Free Software Foundation.
* This program is distributed in the hope it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
* Top level DTS file for CVM:P2888-0001 and CVB:P2822-0000.
#include "common/tegra194-p2888-0001-p2822-0000-common.dtsi"
#include "common/tegra194-p2822-camera-modules.dtsi"
#include "common/tegra194-audio-p2822-0000.dtsi"
#if defined(LINUX_VERSION) && LINUX_VERSION >= 419
/* FIXME: K5.4 overrides */
bpmp {
i2c {
spmic@3c {
interrupt-parent = <&intc>;
interrupts = <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>;
hda@3510000 {
power-domains = <&bpmp TEGRA194_POWER_DOMAIN_DISP>;
resets = <&bpmp TEGRA194_RESET_HDA>,
<&bpmp TEGRA194_RESET_HDA2CODEC_2X>,
<&bpmp TEGRA194_RESET_HDA2HDMICODEC>;
reset-names = "hda", "hda2codec_2x", "hda2hdmi";
serial@3100000 {
compatible = "nvidia,tegra194-hsuart";
tegra-cache {
status = "okay";
#endif
I’ve created a dtsi file for the converter IC. And then I’ve copied the dtsi file to hardware/nvidia/platform/t19x/galen/kernel-dts/common location. The dtsi file looks like this:
tegra194-tc358743.dtsi
* Copyright (c) 2015-2020, NVIDIA CORPORATION. All rights reserved.
* more details.
#include "dt-bindings/clock/tegra194-clock.h"
#define CAM0_RST_L TEGRA194_MAIN_GPIO(H, 3)
#define CAM0_PWDN TEGRA194_MAIN_GPIO(H, 6)
tegra-capture-vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
tc358743_vi_in1: endpoint {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&tc358743_csi_out0>;
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
tc358743_csi_in0: endpoint@0 {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&tc358743_out1>;
port@1 {
reg = <1>;
tc358743_csi_out0: endpoint@1 {
remote-endpoint = <&tc358743_vi_in1>;
i2c@3180000 {
tc358743@0f {
reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
vana-supply = <&p2822_avdd_cam_2v8>;
vif-supply = <&p2822_vdd_1v8_cvb>;
compatible = "toshiba,tc358743";
/* I2C device address */
reg = <0x0f>;
/* V4L2 device node location */
devnode = "video0";
//clocks = <&tegra_car TEGRA210_CLK_EXTERN3>;
#clock-cells = <0>;
//clock-names = "refclk";
//mclk = "cam_mclk1";
//reset-gpios = <&gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
/* Physical dimensions of sensor */
physical_w = "4.713";
physical_h = "3.494";
/* Sensor Model */
sensor_model ="tc358743";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
tc358743_out1: endpoint {
port-index = <0>; /* CSI A */
bus-width = <2>;
phy_mode = "DPHY";
data-lanes = <1 2>;
clock-lanes = <0>;
//clock-noncontinuous;
link-frequencies = /bits/ 64 <594000000>;//297000000///594000000
remote-endpoint = <&tc358743_csi_in0>;
gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_RST_L 0 CAM0_PWDN 0>;
label = "cam0-rst", "cam0-pwdn";
tegra-camera-platform {
status = "okay";
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <2>; // Changed 2 -> 4
max_lane_speed = <1500000>;
min_bits_per_pixel = <16>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module1 {
status = "okay";
badge = "tc358743_top_i2c6_b";
position = "front";
orientation = "1";
drivernode0 {
status = "okay";
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver's v4l2 device name */
devname = "tc358743 6-000f";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/tc358743@0f";
Where should I include this file? And can I compie with nvbuild.sh script? Do I have to use any other method for enabling the driver and compile the kernel?
Regards,
İbrahim
