How to Increase RootFS Size to 64GB on AGX Xavier Industrial SOM
We are testing AGX Xavier Industrial SOM.
We discovered after flashing AGX Xavier Industrial SOM with JetPack 4.6. The RootFS size is only 32GB. Please help guide about how to extend the RootFS size to 64GB.
Are you flashing your AGXI with sdkmanager and it only has 32GB?
Hi WayneWWW,
We failed to flash AGXI with sdkmanager(v1.7.1.8928) somehow. Therefore, we download the Linux_for_Tegra directory via sdkmanager only. And we use the following command to flash AGXI:
cd ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
sudo ./flash.sh jetson-agx-xavier-industrial mmcblk0p1
Sorry about that. That is a known issue in sdkmanager.
Could you share your “df -h” and dmesg with us?
Hi WayneWWW,
Thank you for the info.
Regarding the dmesg and df command, I attach the log. Please check it.
agxi_dmesg_df_lsblk.log (40.7 KB)
Here is the “df -h” and “lsblk” result:
jett@jett-desktop:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p1   28G  5.1G   21G  20% /
none             14G     0   14G   0% /dev
tmpfs            14G  4.0K   14G   1% /dev/shm
tmpfs            14G   22M   14G   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs            14G     0   14G   0% /sys/fs/cgroup
tmpfs           2.8G   12K  2.8G   1% /run/user/120
tmpfs           2.8G     0  2.8G   0% /run/user/1000
jett@jett-desktop:~$ lsblk
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
loop1          7:1    0   16M  1 loop
mtdblock0     31:0    0   64M  0 disk
mtdblock1     31:1    0   32M  0 disk
mmcblk0      179:0    0 59.3G  0 disk
??mmcblk0p1  179:1    0   28G  0 part /
??mmcblk0p2  179:2    0   64M  0 part
??mmcblk0p3  179:3    0   64M  0 part
??mmcblk0p4  179:4    0  448K  0 part
??mmcblk0p5  179:5    0  448K  0 part
??mmcblk0p6  179:6    0   63M  0 part
??mmcblk0p7  179:7    0  512K  0 part
??mmcblk0p8  179:8    0  256K  0 part
??mmcblk0p9  179:9    0  256K  0 part
??mmcblk0p10 179:10   0  300M  0 part
??mmcblk0p11 179:11   0 30.8G  0 part
mmcblk0boot0 179:32   0 31.5M  1 disk
mmcblk0boot1 179:64   0 31.5M  1 disk
mmcblk0rpmb  179:96   0    4M  0 disk
zram0        252:0    0  1.7G  0 disk [SWAP]
zram1        252:1    0  1.7G  0 disk [SWAP]
zram2        252:2    0  1.7G  0 disk [SWAP]
zram3        252:3    0  1.7G  0 disk [SWAP]
zram4        252:4    0  1.7G  0 disk [SWAP]
zram5        252:5    0  1.7G  0 disk [SWAP]
zram6        252:6    0  1.7G  0 disk [SWAP]
zram7        252:7    0  1.7G  0 disk [SWAP]
If you didn’t enable rootfs a/b, then please add -S with 64G in flash.sh.
Hi WayneWWW,
I used the following command and the mmcblk0p1 could be extended to 58GiB.
sudo ./flash.sh -S 62277025792 jetson-agx-xavier-industrial mmcblk0p1
Thank you for your help.
