How to infer the .trt/.engine model on Drive AGX Orin through cross-compile?
Software Version
[√] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
1.9.3.10904
[√] other
Host Machine Version
[√] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
I originally had a C++ file and a trt model that could be inferred in the Windows environment, but now I want to infer the trt model on orin through cross compilation.
My steps are as follows:
  1. Convert the onnx model to a. trt model on the Orin target through trtexec;
  2. Copy the TRT model to the Docker on the host side;
  3. A sampleShuZiRen directory project has been added under/usr/src/tensorrt/samples on the host side. The corresponding Makefile has been written in this directory, and the C++file that can infer trt in the Windows environment has been copied here;
  4. Then compile using “sudo make TARGET=aarch64”.
However, the following error occurred. Is there a corresponding documentation to explain it?
aarch64-linux-gnu-g++ -MM -MF ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.d -MP -MT ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o -Wall -Wno-deprecated-declarations -std=c++14 -I"/usr/include/aarch64-linux-gnu" -I"/usr/include/aarch64-linux-gnu" -I"/usr/local/cuda/targets/aarch64-linux/include" -I"../common" -I"/usr/local/cuda/include" -I"/usr/local/cuda/include" -I"../include" -I"../../include" -I"../../parsers/onnxOpenSource" -D_REENTRANT -DTRT_STATIC=0 ../common/sampleEngines.cpp
Compiling: ../common/sampleEngines.cpp
aarch64-linux-gnu-g++ -Wall -Wno-deprecated-declarations -std=c++14 -I"/usr/include/aarch64-linux-gnu" -I"/usr/include/aarch64-linux-gnu" -I"/usr/local/cuda/targets/aarch64-linux/include" -I"../common" -I"/usr/local/cuda/include" -I"/usr/local/cuda/include" -I"../include" -I"../../include" -I"../../parsers/onnxOpenSource" -D_REENTRANT -DTRT_STATIC=0 -g -c -o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o ../common/sampleEngines.cpp
Linking: ../../bin/sample_shu_zi_ren_debug
aarch64-linux-gnu-g++ -o ../../bin/sample_shu_zi_ren_debug -L"../lib/stubs" -L"../../lib/stubs" -L"/usr/lib/aarch64-linux-gnu/stubs" -L"/usr/lib/aarch64-linux-gnu" -L"/usr/lib/aarch64-linux-gnu/stubs" -L"/usr/lib/aarch64-linux-gnu" -L"/usr/local/cuda/targets/aarch64-linux/lib/stubs" -L"/usr/local/cuda/targets/aarch64-linux/lib" -L"/usr/local/cuda/lib" -Wl,-rpath-link=“/usr/local/cuda/lib” -L"/usr/local/cuda/lib64" -Wl,-rpath-link=“/usr/local/cuda/lib64” -L"../lib" -L"../../lib" -L"../../lib" -Wl,-rpath-link=“../../lib” -L"/usr/lib/x86_64-linux-gnu/lib" -Wl,-rpath-link=“/usr/lib/x86_64-linux-gnu/lib” -L"" -Wl,-rpath-link=“” -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lnvonnxparser -lcudart -lcublas -lcudnn -lrt -ldl -lpthread ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/sampleShuZiRen.o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleInference.o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleUtils.o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleOptions.o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/logger.o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/getOptions.o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleReporting.o ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o -Wl,–end-group
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleInference.o: in function sample::timeDeserialize(sample::InferenceEnvironment&, sample::SystemOptions const&)': /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleInference.cpp:1216: undefined reference to createRuntime()’
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleInference.o: in function sample::getLayerInformation[abi:cxx11](nvinfer1::ICudaEngine*, nvinfer1::IExecutionContext*, nvinfer1::LayerInformationFormat)': /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleInference.cpp:1307: undefined reference to createRuntime()’
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function sample::(anonymous namespace)::CaffeBufferShutter::~CaffeBufferShutter()': /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:56: undefined reference to shutdownCaffeParser()’
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function sample::(anonymous namespace)::UffBufferShutter::~UffBufferShutter()': /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:64: undefined reference to shutdownUffParser()’
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function sample::LazilyDeserializedEngine::get()': /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:110: undefined reference to createRuntime()’
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:114: undefined reference to createRuntime()' /usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function sample::modelToNetwork(sample::ModelOptions const&, sample::BuildOptions const&, nvinfer1::INetworkDefinition&, std::ostream&, std::vector<std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::allocator<std::__cxx11::basic_string<char, std::char_traits, std::allocator > > >)‘:
/usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:252: undefined reference to sampleCreateCaffeParser()' /usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:278: undefined reference to sampleCreateUffParser()’
/usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: /usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:312: undefined reference to createONNXParser(nvinfer1::INetworkDefinition&)' /usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function sample::modelToBuildEnv(sample::ModelOptions const&, sample::BuildOptions const&, sample::SystemOptions&, sample::BuildEnvironment&, std::ostream&)‘:
/usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:1250: undefined reference to createBuilder()' /usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function sample::dumpRefittable(nvinfer1::ICudaEngine&)’:
/usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:1367: undefined reference to createRefitter(nvinfer1::ICudaEngine&)' /usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function sample::timeRefit(nvinfer1::INetworkDefinition const&, nvinfer1::ICudaEngine&, bool)':
/usr/src/tensorrt/samples/sampleShuZiRen/../common/sampleEngines.cpp:1536: undefined reference to createRefitter(nvinfer1::ICudaEngine&)' /usr/lib/gcc-cross/aarch64-linux-gnu/9/../../../../aarch64-linux-gnu/bin/ld: ../../bin/dchobj/sampleShuZiRen/sampleShuZiRen/../common/sampleEngines.o: in function samplesCommon::updateTimingCacheFile(std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&, nvinfer1::ITimingCache const
/usr/src/tensorrt/samples/sampleShuZiRen/../common/common.h:1183: undefined reference to `createBuilder()’
collect2: error: ld returned 1 exit status
make[1]: *** [../Makefile.config:363: ../../bin/sample_shu_zi_ren_debug] Error 1
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleShuZiRen’
make: *** [Makefile:85: all] Error 2
Dear @AlanWang,
I could cross compile the shipped TRT samples with make TARGET=aarch64.
TRT.txt (223.0 KB)
Were you able to compile the TRT shipped samples and notice issue with only your sample?
@SivaRamaKrishnaNV
Thank you very much for your answer.
I could cross compile the shipped TRT samples with make TARGET=aarch64 too.
But, as I mentioned earlier, I want to infer a trt model on Orin through cross compilation. The shipped TRT samples use the onnx model for inference,this is a different place.
So, is there any documentation to infer with trt model?
Dear @AlanWang,
I see you are using the functions(files) used by trtexec. I suspect some issue in your makefile as you are able to compile trtexec and other TRT samples.
