jetson orin nx install jetson sdk components always failed,I want to use jetson sdk components packages to install,how to get it?
Hi
Have you executed the following commands?
sudo apt update
sudo apt install nvidia-jetpack
Please share the error logs.
error log:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-jetpack : Depends: nvidia-jetpack-runtime (= 5.1.3-b29) but it is not going to be installed
Depends: nvidia-jetpack-dev (= 5.1.3-b29) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Could you share the result with this command in Orin NX
head /etc/nv_tegra_release
Is your SDK Manager running on a physical machine with Ubuntu 20.04 to reflash the device?
Ubuntu 18.04
should I use ubuntu 20.04 to install jetson sdk components ?
18.04 is okay
Please try below commands:
sudo apt-get update
sudo apt-get install --reinstall sdkmanager
And run the sdk manager again.
Is your Orin NX a dev kit or the custom carrier board?
I buy it from this store: 亚博智能 NVIDIA英伟达Jetson Orin NX开发板AI套件核心模组块ROS-tmall.com天猫
Here are some suggestions you might try:
Reinstall SDK Manager
sudo apt-get update sudo apt --fix-broken install sudo apt-get install --reinstall sdkmanager
Manually Flash
- Navigate to the directory
~/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/
and run these commands:sudo ./apply_binaries.sh sudo ./tools/l4t_flash_prerequisites.sh sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
Install a Later Version of Jetpack
Consider installing a later version like
Jetpack 6.1
If the SDK Manager fails again (APT system is broken), select the
Jetson Linux
option only as shown in the image.
After a successful flash, execute the following commands on Orin NX:
sudo apt update sudo apt install nvidia-jetpack
Use a Physical Machine with Ubuntu 20.04
- Try using a physical machine running Ubuntu 20.04 instead of a virtual machine (such as VirtualBox, VMware, or WSL) and run the SDK Manager again.
Thanks, I have a try。
