I emulate Jetson Xavier NX on Jetson AGX Xavier.
But I don’t know how to install libraries ( OpenCV, CUDA, etc)
Do you have some tutorials ?
Moving to Jetson AGX Xavier forum so that Jetson team can take a look.
This would depend on which release you are using. If you are using R32.3.1 or newer, then you can probably just use “sudo apt-get ...name...
”. In releases prior to this you would use JetPack/SDK Manager after deselecting flash or host PC content. The release used to originally flash changes which JetPack/SDKM to use. To know your current L4T release use “head -n 1 /etc/nv_tegra_release
To match a JetPack/SDKM release to an L4T release see the table at (you might need to log in there, and then go there again if redirect does not work):
https://developer.nvidia.com/embedded/linux-tegra-archive
Thank you for your reply, linuxdev.
I’m using R32.2.1.So, I try to download and install some deb files.
You might see what shows up with “apt search cuda
” or “apt search opencv
” as an example. You can page long results, e.g., “apt search cuda | less
