I need to install Python to use ultralytics on my Jetson Nano, so I need something above 3.8 at least which is not possible using sudo apt get install.
You can follow this post to install different versions of python in your system using pyenv:
https://www.ridgerun.ai/post/pyenv-simple-python-version-management
You could also use conda:
https://developer.ridgerun.com/wiki/index.php/How_to_Install_Python_with_Conda
Best Regards,
Enrique Ramirez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Thanks! i’ll try it.
