How to install Pytorch 1.0 on Xavier
You can build it from source or install pre-built wheel file.
1. Steps for building from source
[url]https://devtalk.nvidia.com/default/topic/1041716/jetson-agx-xavier/pytorch-install-problem-solved-/post/5284747/#5284747[/url]
2. Pre-built wheel
[url]https://devtalk.nvidia.com/default/topic/1041716/jetson-agx-xavier/pytorch-install-problem-solved-/post/5284880/#5284880[/url]
Thanks a lot.
pip3 install numpy but failed.
Collecting numpy
Using cached https://files.pythonhosted.org/packages/2d/80/1809de155bad674b494248bcfca0e49eb4c5d8bee58f26fe7a0dd45029e2/numpy-1.15.4.zip
Building wheels for collected packages: numpy
Running setup.py bdist_wheel for numpy … error
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-install-nkf6fgqh/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/pip-wheel-p71_qwbw --python-tag cp36:
Running from numpy source directory.
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
blis_info:
libraries blis not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
openblas_info:
libraries openblas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/system_info.py:625: UserWarning:
Atlas (http://math-atlas.sourceforge.net/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [atlas]) or by setting
the ATLAS environment variable.
self.calc_info()
blas_info:
libraries blas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
Blas (BLAS (Basic Linear Algebra Subprograms)) libraries not found.
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
self.calc_info()
blas_src_info:
NOT AVAILABLE
Blas (BLAS (Basic Linear Algebra Subprograms)) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
self.calc_info()
NOT AVAILABLE
/bin/sh: 1: svnversion: not found
non-existing path in ‘numpy/distutils’: ‘site.cfg’
F2PY Version 2
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_3_10_threads_info:
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
<class ‘numpy.distutils.system_info.atlas_3_10_threads_info’>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
<class ‘numpy.distutils.system_info.atlas_3_10_info’>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class ‘numpy.distutils.system_info.atlas_threads_info’>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class ‘numpy.distutils.system_info.atlas_info’>
NOT AVAILABLE
lapack_info:
libraries lapack not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
Lapack (LAPACK — Linear Algebra PACKage) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
self.calc_info()
lapack_src_info:
NOT AVAILABLE
Lapack (LAPACK — Linear Algebra PACKage) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
self.calc_info()
NOT AVAILABLE
/usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: ‘define_macros’
warnings.warn(msg)
running bdist_wheel
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
creating build
creating build/src.linux-aarch64-3.6
creating build/src.linux-aarch64-3.6/numpy
creating build/src.linux-aarch64-3.6/numpy/distutils
building library “npymath” sources
get_default_fcompiler: matching types: ‘[‘gnu95’, ‘intel’, ‘lahey’, ‘pg’, ‘absoft’, ‘nag’, ‘vast’, ‘compaq’, ‘intele’, ‘intelem’, ‘gnu’, ‘g95’, ‘pathf95’, ‘nagfor’]’
customize Gnu95FCompiler
Could not locate executable gfortran
Could not locate executable f95
customize IntelFCompiler
Could not locate executable ifort
Could not locate executable ifc
customize LaheyFCompiler
Could not locate executable lf95
customize PGroupFCompiler
Could not locate executable pgfortran
customize AbsoftFCompiler
Could not locate executable f90
Could not locate executable f77
customize NAGFCompiler
customize VastFCompiler
customize CompaqFCompiler
Could not locate executable fort
customize IntelItaniumFCompiler
Could not locate executable efort
Could not locate executable efc
customize IntelEM64TFCompiler
customize GnuFCompiler
Could not locate executable g77
customize G95FCompiler
Could not locate executable g95
customize PathScaleFCompiler
Could not locate executable pathf95
customize NAGFORCompiler
Could not locate executable nagfor
don’t know how to compile Fortran code on platform ‘posix’
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
compile options: ‘-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -c’
aarch64-linux-gnu-gcc: _configtest.c
aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
success!
removing: _configtest.c _configtest.o _configtest.o.d _configtest
_configtest.c:1:5: warning: conflicting types for built-in function ‘exp’ [-Wbuiltin-declaration-mismatch]
int exp (void);
_configtest.o: In function main': /tmp/pip-install-nkf6fgqh/numpy/_configtest.c:6: undefined reference to
exp’
collect2: error: ld returned 1 exit status
exp’
failure.
int exp (void);
aarch64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
success!
creating build/src.linux-aarch64-3.6/numpy/core
creating build/src.linux-aarch64-3.6/numpy/core/src
creating build/src.linux-aarch64-3.6/numpy/core/src/npymath
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h
adding ‘build/src.linux-aarch64-3.6/numpy/core/src/npymath’ to include_dirs.
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/ieee754.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_complex.c
None - nothing done with h_files = [‘build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h’]
building library “npysort” sources
creating build/src.linux-aarch64-3.6/numpy/core/src/npysort
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/quicksort.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/mergesort.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/heapsort.c
creating build/src.linux-aarch64-3.6/numpy/core/src/private
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/private/npy_partition.h
adding ‘build/src.linux-aarch64-3.6/numpy/core/src/private’ to include_dirs.
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/selection.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/private/npy_binsearch.h
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/binsearch.c
None - nothing done with h_files = [‘build/src.linux-aarch64-3.6/numpy/core/src/private/npy_partition.h’, ‘build/src.linux-aarch64-3.6/numpy/core/src/private/npy_binsearch.h’]
building extension “numpy.core._dummy” sources
Generating build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h
_configtest.c:1:10: fatal error: Python.h: No such file or directory
#include <Python.h>
compilation terminated.
#include <Python.h>
failure.
File “”, line 1, in
File “/tmp/pip-install-nkf6fgqh/numpy/setup.py”, line 403, in
setup_package()
File “/tmp/pip-install-nkf6fgqh/numpy/setup.py”, line 395, in setup_package
setup(**metadata)
File “/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/core.py”, line 169, in setup
return old_setup(**new_attr)
File “/home/nvidia/.local/lib/python3.6/site-packages/setuptools/init.py”, line 143, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/usr/lib/python3/dist-packages/wheel/bdist_wheel.py”, line 179, in run
self.run_command(‘build’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build.py”, line 47, in run
old_build.run(self)
File “/usr/lib/python3.6/distutils/command/build.py”, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File “/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py”, line 148, in run
self.build_sources()
File “/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py”, line 165, in build_sources
self.build_extension_sources(ext)
File “/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py”, line 324, in build_extension_sources
sources = self.generate_sources(sources, ext)
File “/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py”, line 377, in generate_sources
source = func(extension, build_dir)
File “numpy/core/setup.py”, line 422, in generate_config_h
moredefs, ignored = cocache.check_types(config_cmd, ext, build_dir)
File “numpy/core/setup.py”, line 48, in check_types
out = check_types(*a, **kw)
File “numpy/core/setup.py”, line 281, in check_types
“install {0}-dev|{0}-devel.”.format(python))
SystemError: Cannot compile ‘Python.h’. Perhaps you need to install python-dev|python-devel.
Failed building wheel for numpy
Running setup.py clean for numpy
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-install-nkf6fgqh/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” clean --all:
setup.py clean
is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add --force
to your command to use it anyway if you must (unsupported).
Failed cleaning build dir for numpy
Failed to build numpy
Installing collected packages: numpy
Running setup.py install for numpy … error
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-install-nkf6fgqh/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-record-x9ypoew1/install-record.txt --single-version-externally-managed --compile:
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install numpy` (last NumPy release on PyPi)
blas_opt_info:
blas_mkl_info:
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
self.calc_info()
blas_info:
libraries blas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
Blas (http://www.netlib.org/blas/) libraries not found.
self.calc_info()
blas_src_info:
NOT AVAILABLE
Blas (http://www.netlib.org/blas/) sources not found.
self.calc_info()
NOT AVAILABLE
non-existing path in 'numpy/distutils': 'site.cfg'
F2PY Version 2
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
NOT AVAILABLE
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
Lapack (http://www.netlib.org/lapack/) libraries not found.
self.calc_info()
lapack_src_info:
NOT AVAILABLE
Lapack (http://www.netlib.org/lapack/) sources not found.
self.calc_info()
NOT AVAILABLE
/usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: 'define_macros'
warnings.warn(msg)
running install
running build
running config_cc
running config_fc
running build_src
build_src
building library "npymath" sources
get_default_fcompiler: matching types: '['gnu95', 'intel', 'lahey', 'pg', 'absoft', 'nag', 'vast', 'compaq', 'intele', 'intelem', 'gnu', 'g95', 'pathf95', 'nagfor']'
don't know how to compile Fortran code on platform 'posix'
compile options: '-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -c'
success!
int exp (void);
_configtest.o: In function `main':
/tmp/pip-install-nkf6fgqh/numpy/_configtest.c:6: undefined reference to `exp'
failure.
int exp (void);
success!
adding 'build/src.linux-aarch64-3.6/numpy/core/src/npymath' to include_dirs.
None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h']
building library "npysort" sources
adding 'build/src.linux-aarch64-3.6/numpy/core/src/private' to include_dirs.
None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/private/npy_partition.h', 'build/src.linux-aarch64-3.6/numpy/core/src/private/npy_binsearch.h']
building extension "numpy.core._dummy" sources
#include <Python.h>
#include <Python.h>
failure.
File "<string>", line 1, in <module>
File "/tmp/pip-install-nkf6fgqh/numpy/setup.py", line 403, in <module>
setup_package()
File "/tmp/pip-install-nkf6fgqh/numpy/setup.py", line 395, in setup_package
setup(**metadata)
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/core.py", line 169, in setup
File "/home/nvidia/.local/lib/python3.6/site-packages/setuptools/__init__.py", line 143, in setup
File "/usr/lib/python3.6/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.6/distutils/dist.py", line 955, in run_commands
File "/usr/lib/python3.6/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/install.py", line 62, in run
r = self.setuptools_run()
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/install.py", line 36, in setuptools_run
return distutils_install.run(self)
File "/usr/lib/python3.6/distutils/command/install.py", line 589, in run
self.run_command('build')
File "/usr/lib/python3.6/distutils/cmd.py", line 313, in run_command
cmd_obj.run()
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build.py", line 47, in run
old_build.run(self)
File "/usr/lib/python3.6/distutils/command/build.py", line 135, in run
cmd_obj.run()
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py", line 148, in run
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py", line 165, in build_sources
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py", line 324, in build_extension_sources
File "/tmp/pip-install-nkf6fgqh/numpy/numpy/distutils/command/build_src.py", line 377, in generate_sources
File "numpy/core/setup.py", line 422, in generate_config_h
File "numpy/core/setup.py", line 48, in check_types
File "numpy/core/setup.py", line 281, in check_types
"install {0}-dev|{0}-devel.".format(python))
SystemError: Cannot compile 'Python.h'. Perhaps you need to install python-dev|python-devel.
Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-install-nkf6fgqh/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-record-x9ypoew1/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-install-nkf6fgqh/numpy/
sudo apt-get install python3-numpy
The error indicates that the app cannot find the python related header:
Please install python developer tool first.
sudo apt-get install python-dev # for python2.x installs
sudo apt-get install python3-dev # for python3.x installs
never mind
sudo pip install pyyaml
Requirement already satisfied: pyyaml in /usr/lib/python3/dist-packages (3.12)
My python version is 3.6.9.When I execute command ‘sudo apt-get install python3-dev’,it prompt me as shown below
When I execute command ‘sudo apt-get install python3.6-dev’,it prompt me as shown below
The following packages have unmet dependencies:
python3.6-dev : Depends: python3.6 (= 3.6.5-3) but 3.6.9-1~18.04 is to be installed
Depends: libpython3.6-dev (= 3.6.5-3) but it is not going to be installed
Depends: libpython3.6 (= 3.6.5-3) but 3.6.9-1~18.04 is to be installed
E: Unable to correct problems, you have held broken packages.
It looks like the Python version is incompatible
Hi 1123864825,
Please open a new topic for your issue. Thanks
