I run the demo,and some packages must be installed,but on TX2,use python3.6 run the demo ,some errors occur,so how to solve the problems?
import skimage.io as io
import skimage.transform as trans
ModuleNotFoundError: No module named ‘skimage’
import tqdm
ModuleNotFoundError: No module named ‘tqdm’
import matplotlib.pyplot as plt
ModuleNotFoundError: No module named ‘matplotlib’
from osgeo.gdalconst import *
from osgeo import gdal
ModuleNotFoundError: No module named ‘osgeo’
And,pip3 list is as follows
root@tx2:~# pip3 list
Package Version
absl-py 0.8.0
apt-clone 0.2.1
apturl 0.5.2
asn1crypto 0.24.0
astor 0.8.0
beautifulsoup4 4.6.0
blinker 1.4
Brlapi 0.6.6
certifi 2018.1.18
chardet 3.0.4
cryptography 2.1.4
cupshelpers 1.0
cycler 0.10.0
Cython 0.29.14
decorator 4.1.2
defer 1.0.6
distro-info 0.18ubuntu0.18.04.1
feedparser 5.2.1
gast 0.3.2
google-pasta 0.1.7
graphsurgeon 0.4.1
grpcio 1.24.0
h5py 2.10.0
html5lib 0.999999999
httplib2 0.9.2
idna 2.6
joblib 0.14.0
Keras 2.3.1
Keras-Applications 1.0.8
Keras-Preprocessing 1.1.0
keyring 10.6.0
keyrings.alt 3.0
kiwisolver 1.1.0
language-selector 0.1
launchpadlib 1.10.6
lazr.restfulclient 0.13.5
lazr.uri 1.0.3
louis 3.5.0
lxml 4.2.1
macaroonbakery 1.1.3
Mako 1.0.7
Markdown 3.1.1
MarkupSafe 1.0
mock 3.0.5
numpy 1.16.4
oauth 1.0.1
oauthlib 2.0.6
olefile 0.45.1
PAM 0.4.2
Pillow 5.1.0
pip 19.2.3
portpicker 1.3.1
protobuf 3.9.2
psutil 5.6.3
py-cpuinfo 5.0.0
pycairo 1.16.2
pycrypto 2.6.1
pycups 1.9.73
pygobject 3.26.1
PyICU 1.9.8
PyJWT 1.5.3
pymacaroons 0.13.0
PyNaCl 1.1.2
pyparsing 2.4.2
pyRFC3339 1.0
python-apt 1.6.4
python-dateutil 2.6.1
python-debian 0.1.32
pytz 2018.3
pyxdg 0.25
PyYAML 3.12
requests 2.22.0
requests-unixsocket 0.1.5
scikit-learn 0.21.3
scipy 0.19.1
SecretStorage 2.3.1
setuptools 41.4.0
simplejson 3.13.2
six 1.12.0
sklearn 0.0
ssh-import-id 5.7
system-service 0.3
systemd-python 234
tensorboard 1.14.0
tensorflow-estimator 1.14.0
tensorflow-gpu 1.14.0+nv19.7
tensorrt 5.1.6.1
termcolor 1.1.0
ubuntu-drivers-common 0.0.0
uff 0.6.3
unity-scope-calculator 0.1
unity-scope-chromiumbookmarks 0.1
unity-scope-colourlovers 0.1
unity-scope-devhelp 0.1
unity-scope-firefoxbookmarks 0.1
unity-scope-manpages 0.1
unity-scope-openclipart 0.1
unity-scope-texdoc 0.1
unity-scope-tomboy 0.1
unity-scope-virtualbox 0.1
unity-scope-yelp 0.1
unity-scope-zotero 0.1
urllib3 1.22
wadllib 1.3.2
webencodings 0.5
Werkzeug 0.16.0
wheel 0.30.0
wrapt 1.11.2
xkit 0.0.0
zope.interface 4.3.2
WARNING: You are using pip version 19.2.3, however version 19.3.1 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
skimage , tqdm and matplotlib can be installed directly via pip3 .
Please check the following command:
sudo pip3 install scikit-image
sudo pip3 install tqdm matplotlib
Please noticed that the installation of skimage may take hours to finish since there are some compiling steps.
For gdal, here is a 2.0 package for ARM system:
https://packages.debian.org/buster/arm64/libgdal20/download
It’s recommended to give it a try first.
I tried,but failed
root@tx2:~# sudo pip3 install tqdm matplotlib
Keyring is skipped due to an exception: org.freedesktop.DBus.Error.TimedOut: Failed to activate service ‘org.freedesktop.secrets’: timed out (service_start_timeout=120000ms)
Requirement already satisfied: tqdm in /usr/local/lib/python3.6/dist-packages (4.38.0)
Collecting matplotlib
Using cached https://files.pythonhosted.org/packages/12/d1/7b12cd79c791348cb0c78ce6e7d16bd72992f13c9f1e8e43d2725a6d8adf/matplotlib-3.1.1.tar.gz
Requirement already satisfied: cycler>=0.10 in /usr/local/lib/python3.6/dist-packages (from matplotlib) (0.10.0)
Requirement already satisfied: kiwisolver>=1.0.1 in /usr/local/lib/python3.6/dist-packages (from matplotlib) (1.1.0)
Requirement already satisfied: pyparsing!=2.0.4,!=2.1.2,!=2.1.6,>=2.0.1 in /usr/local/lib/python3.6/dist-packages (from matplotlib) (2.4.2)
Requirement already satisfied: python-dateutil>=2.1 in /usr/lib/python3/dist-packages (from matplotlib) (2.6.1)
Requirement already satisfied: numpy>=1.11 in /usr/local/lib/python3.6/dist-packages (from matplotlib) (1.16.4)
Requirement already satisfied: six in /usr/local/lib/python3.6/dist-packages (from cycler>=0.10->matplotlib) (1.12.0)
Requirement already satisfied: setuptools in /usr/local/lib/python3.6/dist-packages (from kiwisolver>=1.0.1->matplotlib) (41.4.0)
Building wheels for collected packages: matplotlib
Building wheel for matplotlib (setup.py) … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-t9vn7vih/matplotlib/setup.py’“'”‘; file =’“'”‘/tmp/pip-install-t9vn7vih/matplotlib/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file );code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file , ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-vr4151ha --python-tag cp36
cwd: /tmp/pip-install-t9vn7vih/matplotlib/
Complete output (505 lines):
Edit setup.cfg to change the build options
BUILDING MATPLOTLIB
matplotlib: yes [3.1.1]
python: yes [3.6.8 (default, Aug 20 2019, 17:12:48) [GCC 8.3.0]]
platform: yes [linux]
OPTIONAL SUBPACKAGES
sample_data: yes [installing]
tests: no [skipping due to configuration]
OPTIONAL BACKEND EXTENSIONS
agg: yes [installing]
tkagg: yes [installing; run-time loading from Python Tcl/Tk]
macosx: no [Mac OS-X only]
OPTIONAL PACKAGE DATA
dlls: no [skipping due to configuration]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6
copying lib/pylab.py → build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_pylab_helpers.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/scale.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/lines.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/sankey.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/dates.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_constrained_layout.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_cm_listed.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/backend_managers.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/legend_handler.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/mlab.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/bezier.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/rcsetup.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/quiver.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/texmanager.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/contour.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/streamplot.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/font_manager.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/legend.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/docstring.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/afm.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/transforms.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/tight_bbox.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/spines.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/hatch.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/container.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/image.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/textpath.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_layoutbox.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/cm.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/animation.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/patches.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/mathtext.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_animation_data.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_color_data.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/category.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_cm.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/backend_tools.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/figure.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_mathtext_data.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/dviread.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/pyplot.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/axis.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/widgets.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/fontconfig_pattern.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/artist.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/init .py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/tight_layout.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/collections.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/colorbar.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_version.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/path.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/gridspec.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/type1font.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/stackplot.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/text.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/markers.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/backend_bases.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/pylab.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/blocking_input.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/table.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/ticker.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/offsetbox.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/patheffects.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/units.py → build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/colors.py → build/lib.linux-aarch64-3.6/matplotlib
creating build/lib.linux-aarch64-3.6/mpl_toolkits
copying lib/mpl_toolkits/init .py → build/lib.linux-aarch64-3.6/mpl_toolkits
creating build/lib.linux-aarch64-3.6/matplotlib/projections
copying lib/matplotlib/projections/polar.py → build/lib.linux-aarch64-3.6/matplotlib/projections
copying lib/matplotlib/projections/init .py → build/lib.linux-aarch64-3.6/matplotlib/projections
copying lib/matplotlib/projections/geo.py → build/lib.linux-aarch64-3.6/matplotlib/projections
creating build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/exceptions.py → build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/decorators.py → build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/conftest.py → build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/init .py → build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/determinism.py → build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/compare.py → build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/disable_internet.py → build/lib.linux-aarch64-3.6/matplotlib/testing
creating build/lib.linux-aarch64-3.6/matplotlib/cbook
copying lib/matplotlib/cbook/deprecation.py → build/lib.linux-aarch64-3.6/matplotlib/cbook
copying lib/matplotlib/cbook/init .py → build/lib.linux-aarch64-3.6/matplotlib/cbook
creating build/lib.linux-aarch64-3.6/matplotlib/sphinxext
copying lib/matplotlib/sphinxext/plot_directive.py → build/lib.linux-aarch64-3.6/matplotlib/sphinxext
copying lib/matplotlib/sphinxext/mathmpl.py → build/lib.linux-aarch64-3.6/matplotlib/sphinxext
copying lib/matplotlib/sphinxext/init .py → build/lib.linux-aarch64-3.6/matplotlib/sphinxext
creating build/lib.linux-aarch64-3.6/matplotlib/axes
copying lib/matplotlib/axes/_secondary_axes.py → build/lib.linux-aarch64-3.6/matplotlib/axes
copying lib/matplotlib/axes/_base.py → build/lib.linux-aarch64-3.6/matplotlib/axes
copying lib/matplotlib/axes/init .py → build/lib.linux-aarch64-3.6/matplotlib/axes
copying lib/matplotlib/axes/_axes.py → build/lib.linux-aarch64-3.6/matplotlib/axes
copying lib/matplotlib/axes/_subplots.py → build/lib.linux-aarch64-3.6/matplotlib/axes
creating build/lib.linux-aarch64-3.6/matplotlib/style
copying lib/matplotlib/style/core.py → build/lib.linux-aarch64-3.6/matplotlib/style
copying lib/matplotlib/style/init .py → build/lib.linux-aarch64-3.6/matplotlib/style
creating build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/wx_compat.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_agg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_tkcairo.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_qt5cairo.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/tkagg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_pdf.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_qt5.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_webagg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_gtk3agg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_qt4agg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/_backend_pdf_ps.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/qt_compat.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_svg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_gtk3cairo.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_nbagg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_wxcairo.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_cairo.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/windowing.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_qt4cairo.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_template.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_qt5agg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_pgf.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_qt4.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_tkagg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_gtk3.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_wxagg.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_ps.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/_backend_tk.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/init .py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_wx.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_webagg_core.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_macosx.py → build/lib.linux-aarch64-3.6/matplotlib/backends
copying lib/matplotlib/backends/backend_mixed.py → build/lib.linux-aarch64-3.6/matplotlib/backends
creating build/lib.linux-aarch64-3.6/matplotlib/compat
copying lib/matplotlib/compat/subprocess.py → build/lib.linux-aarch64-3.6/matplotlib/compat
copying lib/matplotlib/compat/init .py → build/lib.linux-aarch64-3.6/matplotlib/compat
creating build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/tripcolor.py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/trirefine.py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/trifinder.py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/tricontour.py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/triangulation.py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/init .py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/tritools.py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/triinterpolate.py → build/lib.linux-aarch64-3.6/matplotlib/tri
copying lib/matplotlib/tri/triplot.py → build/lib.linux-aarch64-3.6/matplotlib/tri
creating build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/StrConverter.py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/UnitDblConverter.py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/UnitDblFormatter.py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/Epoch.py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/init .py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/Duration.py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/EpochConverter.py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
copying lib/matplotlib/testing/jpl_units/UnitDbl.py → build/lib.linux-aarch64-3.6/matplotlib/testing/jpl_units
creating build/lib.linux-aarch64-3.6/matplotlib/backends/qt_editor
copying lib/matplotlib/backends/qt_editor/figureoptions.py → build/lib.linux-aarch64-3.6/matplotlib/backends/qt_editor
copying lib/matplotlib/backends/qt_editor/formsubplottool.py → build/lib.linux-aarch64-3.6/matplotlib/backends/qt_editor
copying lib/matplotlib/backends/qt_editor/_formlayout.py → build/lib.linux-aarch64-3.6/matplotlib/backends/qt_editor
copying lib/matplotlib/backends/qt_editor/init .py → build/lib.linux-aarch64-3.6/matplotlib/backends/qt_editor
copying lib/matplotlib/backends/qt_editor/formlayout.py → build/lib.linux-aarch64-3.6/matplotlib/backends/qt_editor
creating build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/clip_path.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/axes_rgb.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/axes_grid.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/axisline_style.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/axis_artist.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/floating_axes.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/angle_helper.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/grid_finder.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/parasite_axes.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/axes_divider.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/grid_helper_curvelinear.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/init .py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
copying lib/mpl_toolkits/axisartist/axislines.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axisartist
creating build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/clip_path.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/axes_rgb.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/axes_grid.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/axisline_style.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/axis_artist.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/floating_axes.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/angle_helper.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/axes_size.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/grid_finder.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/anchored_artists.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/parasite_axes.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/axes_divider.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/grid_helper_curvelinear.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/init .py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/colorbar.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/axislines.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
copying lib/mpl_toolkits/axes_grid/inset_locator.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid
creating build/lib.linux-aarch64-3.6/mpl_toolkits/mplot3d
copying lib/mpl_toolkits/mplot3d/axis3d.py → build/lib.linux-aarch64-3.6/mpl_toolkits/mplot3d
copying lib/mpl_toolkits/mplot3d/art3d.py → build/lib.linux-aarch64-3.6/mpl_toolkits/mplot3d
copying lib/mpl_toolkits/mplot3d/proj3d.py → build/lib.linux-aarch64-3.6/mpl_toolkits/mplot3d
copying lib/mpl_toolkits/mplot3d/init .py → build/lib.linux-aarch64-3.6/mpl_toolkits/mplot3d
copying lib/mpl_toolkits/mplot3d/axes3d.py → build/lib.linux-aarch64-3.6/mpl_toolkits/mplot3d
creating build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/axes_rgb.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/axes_grid.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/axes_size.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/anchored_artists.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/parasite_axes.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/axes_divider.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/init .py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/mpl_axes.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/colorbar.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
copying lib/mpl_toolkits/axes_grid1/inset_locator.py → build/lib.linux-aarch64-3.6/mpl_toolkits/axes_grid1
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/matplotlib_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/back.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/filesave_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Helvetica.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSerif-Bold.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/matplotlibrc → build/lib.linux-aarch64-3.6/matplotlib/mpl-data
copying lib/matplotlib/mpl-data/images/filesave.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/putb8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizFourSymReg.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/stylelib/seaborn-pastel.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSerif.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/matplotlib.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/LICENSE_DEJAVU → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/filesave.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/filesave_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/stylelib/_classic_test.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/afm/phvbo8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/move.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/STIXNonUni.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Courier.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/stylelib/seaborn-whitegrid.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/afm/phvb8an.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/stylelib/seaborn-white.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/stylelib/seaborn-bright.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizOneSymBol.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/back.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/forward_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/stylelib/seaborn-darkgrid.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/images/help.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/images/ui-icons_777620_256x240.png → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/images
copying lib/matplotlib/mpl-data/images/help.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/home_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Times-Italic.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/images/qt4_editor_options.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery/js
copying lib/matplotlib/backends/web_backend/jquery/js/jquery.min.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery/js
copying lib/matplotlib/mpl-data/images/help.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/home.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/images/ui-icons_ffffff_256x240.png → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/images
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Times-Bold.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSerifDisplay.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.min.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/stylelib/seaborn-colorblind.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/afm/cmsy10.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/zoom_to_rect.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/js
copying lib/matplotlib/backends/web_backend/js/nbagg_mpl.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/js
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Courier-Oblique.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/images/back_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/ptmbi8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Courier-Bold.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Courier-BoldOblique.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/fonts/afm/phvr8an.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/external
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/external/jquery
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/external/jquery/jquery.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/external/jquery
copying lib/matplotlib/mpl-data/fonts/afm/pncri8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/backends/web_backend/js/mpl.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/js
copying lib/matplotlib/mpl-data/fonts/afm/cmr10.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/AUTHORS.txt → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/readme.txt → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/stylelib/Solarize_Light2.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
creating build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/css
copying lib/matplotlib/backends/web_backend/css/boilerplate.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/css
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/sample_data/percent_bachelors_degrees_women_usa.csv → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/afm/pagko8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSerif-BoldItalic.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/afm/ptmb8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/sample_data/ada.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.min.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/fonts/afm/pbkli8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/pncbi8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/help_large.ppm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/STIXNonUniBolIta.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/sample_data/ct.raw.gz → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizOneSymReg.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/matplotlib.ppm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/phvro8an.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/LICENSE_STIX → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/hand.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/putr8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/pncr8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/move.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/forward.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/stylelib/seaborn-deep.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/stylelib/tableau-colorblind10.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/stylelib/grayscale.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/images/subplots.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/home.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Times-Roman.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/LICENSE.txt → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/images/move_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/images/ui-icons_555555_256x240.png → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/images
copying lib/matplotlib/mpl-data/sample_data/embedding_in_wx3.xrc → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/images/back.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/sample_data/data_x_x2_x3.csv → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/ZapfDingbats.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/fonts/afm/cmtt10.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.theme.min.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSansMono-BoldOblique.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSans.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/ttf/cmmi10.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/sample_data/grace_hopper.jpg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/backends/web_backend/ipython_inline_figure.html → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend
copying lib/matplotlib/backends/web_backend/jquery/js/jquery.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery/js
copying lib/matplotlib/mpl-data/fonts/ttf/cmss10.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/matplotlib.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.structure.min.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSans-Bold.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/stylelib/seaborn-dark.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/images/help.ppm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/STIXNonUniBol.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/back.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/home_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/move_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/images/ui-icons_777777_256x240.png → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/images
copying lib/matplotlib/mpl-data/images/subplots.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/subplots.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/sample_data/Minduka_Present_Blue_Pack.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/afm/pagd8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/STIXGeneralBolIta.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.structure.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/sample_data/README.txt → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/images/hand_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/matplotlib.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/package.json → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/sample_data/jacksboro_fault_dem.npz → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/images/filesave.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/sample_data/aapl.npz → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/backends/web_backend/js/mpl_tornado.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/js
copying lib/matplotlib/mpl-data/fonts/ttf/cmr10.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/afm/pbkd8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/backends/web_backend/css/page.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/css
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSans-BoldOblique.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/back_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/STIXNonUniIta.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/hand.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/subplots.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSans-Oblique.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/sample_data/membrane.dat → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/ttf/STIXGeneral.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Helvetica-BoldOblique.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/fonts/afm/pcrro8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/phvl8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/zoom_to_rect_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.theme.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/images/home.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/stylelib/dark_background.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/afm/pzdr.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizThreeSymReg.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizFourSymBol.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/stylelib/seaborn-dark-palette.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/sample_data/grace_hopper.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/ttf/cmb10.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/images/ui-icons_cc0000_256x240.png → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/images
copying lib/matplotlib/mpl-data/stylelib/classic.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/backends/web_backend/single_figure.html → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend
copying lib/matplotlib/mpl-data/stylelib/seaborn-ticks.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Times-BoldItalic.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/images/hand.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/sample_data/None_vs_nearest-pdf.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/images/qt4_editor_options_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/stylelib/fivethirtyeight.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/ttf/STIXGeneralBol.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/afm/pzcmi8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/pbkdi8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/stylelib/ggplot.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/sample_data/topobathy.npz → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/afm/cmex10.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/stylelib/seaborn-notebook.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/afm/ptmr8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/stylelib/bmh.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/sample_data/eeg.dat → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/images/qt4_editor_options.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/index.html → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/mpl-data/fonts/afm/pplri8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/filesave.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/zoom_to_rect_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Helvetica-Oblique.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/backends/web_backend/all_figures.html → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend
copying lib/matplotlib/mpl-data/fonts/afm/phvr8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/hand.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSerif-Italic.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/afm/pcrb8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/backends/web_backend/nbagg_uat.ipynb → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend
creating build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data/axes_grid
copying lib/matplotlib/mpl-data/sample_data/axes_grid/bivariate_normal.npy → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data/axes_grid
copying lib/matplotlib/mpl-data/fonts/afm/pncb8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/backends/web_backend/css/fbm.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/css
copying lib/matplotlib/mpl-data/sample_data/logo2.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/afm/putri8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/help_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/phvlo8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Helvetica-Bold.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/fonts/afm/pplb8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/cmtt10.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/forward.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/ptmri8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/stylelib/fast.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/sample_data/goog.npz → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/pdfcorefonts/Symbol.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/pdfcorefonts
copying lib/matplotlib/mpl-data/images/move.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/pplr8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizTwoSymBol.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/qt4_editor_options.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/stylelib/seaborn-paper.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/afm/phvro8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/pplbi8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSansMono-Oblique.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/subplots_large.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/cmex10.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/stylelib/seaborn-poster.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/stylelib/seaborn-talk.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/afm/pcrr8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizThreeSymBol.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/afm/pagk8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/pagdo8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSansMono.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/stylelib/seaborn-muted.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/images/forward.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/pbkl8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/stylelib/seaborn.mplstyle → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/stylelib
copying lib/matplotlib/mpl-data/fonts/ttf/cmsy10.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/zoom_to_rect.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/zoom_to_rect.gif → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/sample_data/msft.csv → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/sample_data/s1045.ima.gz → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/fonts/afm/psyr.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/forward_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/putbi8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.css → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/jquery-ui.js → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1
copying lib/matplotlib/backends/web_backend/jquery-ui-1.12.1/images/ui-icons_444444_256x240.png → build/lib.linux-aarch64-3.6/matplotlib/backends/web_backend/jquery-ui-1.12.1/images
copying lib/matplotlib/mpl-data/fonts/afm/pcrbo8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/STIXGeneralItalic.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/afm/cmmi10.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSansDisplay.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/home.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/afm/phvbo8an.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/fonts/afm/phvb8a.afm → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/afm
copying lib/matplotlib/mpl-data/images/forward.svg → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/sample_data/demodata.csv → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/sample_data
copying lib/matplotlib/mpl-data/images/subplots_large.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/DejaVuSansMono-Bold.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizFiveSymReg.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
copying lib/matplotlib/mpl-data/images/move.pdf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/images/zoom_to_rect.png → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/images
copying lib/matplotlib/mpl-data/fonts/ttf/STIXSizTwoSymReg.ttf → build/lib.linux-aarch64-3.6/matplotlib/mpl-data/fonts/ttf
UPDATING build/lib.linux-aarch64-3.6/matplotlib/_version.py
set build/lib.linux-aarch64-3.6/matplotlib/_version.py to ‘3.1.1’
running build_ext
building ‘matplotlib.ft2font’ extension
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/src
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DFREETYPE_BUILD_TYPE=system -DPY_ARRAY_UNIQUE_SYMBOL=MPL_matplotlib_ft2font_ARRAY_API -DNPY_NO_DEPRECATED_API=NPY_1_7_API_VERSION -D__STDC_FORMAT_MACROS=1 -Iextern/agg24-svn/include -I/usr/local/lib/python3.6/dist-packages/numpy/core/include -I/usr/include/python3.6m -c src/checkdep_freetype2.c -o build/temp.linux-aarch64-3.6/src/checkdep_freetype2.o
src/checkdep_freetype2.c:1:10: fatal error: ft2build.h: No such file or directory
include <ft2build.h>
compilation terminated.
error: command ‘aarch64-linux-gnu-gcc’ failed with exit status 1
ERROR: Failed building wheel for matplotlib
Running setup.py clean for matplotlib
Failed to build matplotlib
Installing collected packages: matplotlib
Running setup.py install for matplotlib … error
command: /usr/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-t9vn7vih/matplotlib/setup.py’“'”‘; file =’“'”‘/tmp/pip-install-t9vn7vih/matplotlib/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file );code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file , ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-45qmut5z/install-record.txt --single-version-externally-managed --compile
BUILDING MATPLOTLIB
running install
running build
running build_py
creating build
copying lib/pylab.py -> build/lib.linux-aarch64-3.6
copying lib/matplotlib/_pylab_helpers.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/scale.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/lines.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/sankey.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/dates.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_constrained_layout.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_cm_listed.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/backend_managers.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/legend_handler.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/mlab.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/bezier.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/rcsetup.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/quiver.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/texmanager.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/contour.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/streamplot.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/font_manager.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/legend.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/docstring.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/afm.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/transforms.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/tight_bbox.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/spines.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/hatch.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/container.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/image.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/textpath.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_layoutbox.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/cm.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/animation.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/patches.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/mathtext.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_animation_data.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_color_data.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/category.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_cm.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/backend_tools.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/figure.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_mathtext_data.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/dviread.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/pyplot.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/axis.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/widgets.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/fontconfig_pattern.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/artist.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/__init__.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/tight_layout.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/collections.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/colorbar.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/_version.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/path.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/gridspec.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/type1font.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/stackplot.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/text.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/markers.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/backend_bases.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/pylab.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/blocking_input.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/table.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/ticker.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/offsetbox.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/patheffects.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/units.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/matplotlib/colors.py -> build/lib.linux-aarch64-3.6/matplotlib
copying lib/mpl_toolkits/__init__.py -> build/lib.linux-aarch64-3.6/mpl_toolkits
copying lib/matplotlib/projections/polar.py -> build/lib.linux-aarch64-3.6/matplotlib/projections
copying lib/matplotlib/projections/__init__.py -> build/lib.linux-aarch64-3.6/matplotlib/projections
copying lib/matplotlib/projections/geo.py -> build/lib.linux-aarch64-3.6/matplotlib/projections
copying lib/matplotlib/testing/exceptions.py -> build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/decorators.py -> build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/conftest.py -> build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/__init__.py -> build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/determinism.py -> build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/compare.py -> build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/testing/disable_internet.py -> build/lib.linux-aarch64-3.6/matplotlib/testing
copying lib/matplotlib/cbook/deprecation.py -> build/lib.linux-aarch64-3.6/matplotlib/cbook
copying lib/matplotlib/cbook/__init__.py -> build/lib.linux-aarch64-3.6/matplotlib/cbook
AastaLLL:
skimage , tqdm and matplotlib can be installed directly via pip3 .
Please check the following command:
sudo pip3 install scikit-image
Please noticed that the installation of skimage may take hours to finish since there are some compiling steps.
For gdal, here is a 2.0 package for ARM system:
https://packages.debian.org/buster/arm64/libgdal20/download
It’s recommended to give it a try first.
Thanks for your advice ,i tried but failed.I can’t install any package ,and errors is as the lasted reply,please tell me how to slove these problems.
It looks like there is no freetype library in your environment.
Could you install it with this command and try it again?
$ sudo apt-get install libfreetype6-dev
I have the same problem,when I try
libfreetype6-dev:depends:libfreetype6(=2.6.1-0.1ubuntu2.4) but 2.8.1-2ubuntu2 is to be installed
how can I solve it?
AastaLLL:
how can I solve it?
