All kernel-build files are copyied in Linux_for_Tegra/kernel. Is it okey?
Jachen, I did dto update and flashing and found /sys/devices/aon_echo/data_channel but how to communicate each other?
Mr. jachen,
Could you answer above question?
Hello All,
Anyone know above question?
Hello, hamzaygrtc:
Good to know that you got /sys/devices/aon_echo/data_channel.
After that, you can echo/cat strings to/from that sysFS node, and that string will be transferred from CCPLEX (Linux) to SPE R5 (FreeRTOS).
You can check SPE FW source rt-aux-cpu-demo/app/ivc-echo-task.c for details.
br
Chenjian
Hello jachen,
I checked ivc-echo-task.c but which function will be used read and write for string I couldn’t understand. Not worked. Could you tell me a example read and write for both sides?
in file rt-aux-cpu-demo/app/ivc-echo-task.c function ivc_echo_task_process_ivc_messages, there’s a loop to get messages. and ivc_echo_task_write_msg to send messages, from SPE side.
br
ChenJian
hello jachen,
I tried debug following code but not get in loop . program cutting. If I put my function above I can see debug output why this happening? tegra_uart_write_now(&UART_APP_PORT, tx_message4, tx_len4);
ret = xEventGroupWaitBits(state->wait_event,
EVENT_WAIT_ALL_BITS,
pdFALSE,
pdTRUE,
portMAX_DELAY); // not get in this below of this code
static portTASK_FUNCTION(ivc_echo_task, pvParameters)
struct ivc_echo_task_state *state = pvParameters;
EventBits_t ret;
for (;;) {
pdFALSE,
pdTRUE,
char tx_message4[] = "m100\r\n";
int tx_len4 = sizeof(tx_message4) - 1;
vTaskDelay(1000);
if ((ret & EVENT_WAIT_ALL_BITS) == EVENT_WAIT_ALL_BITS) {
xEventGroupClearBits(state->wait_event,
EVENT_WAIT_BIT);
ivc_echo_task_process_ivc_messages(state);
In Linux side, execute ‘echo xxx >…/…/data_channel’, and in SPE FW function ivc_echo_task_process_ivc_messages
dbgprintf("IVC read count: %d\r\n", count);
should be executed and then SPE FW will write back the message by ivc_echo_task_write_msg.
br
ChenJian
hi,
I got deleted this code.
pdFALSE,
pdTRUE,
run then got in ivc_echo_task_process_ivc_messages but nothing reading
with
cat data_channel
my suggestion is to add some print code and understand the logic first. then you can try to make some changes.
br
Chenjian
You need not add ivc_echo_task_init. That will be called in main.c - late_init.
Do you mean that the ivc is enabled in default that we don’t need to change anything, just compile and flash to the SPE, then the SPE part works?
Hello, hao.ye:
It should be. That part of task has already been enabled in SPE FW for SDK 32.4.2
If that does not work as expected, you can start a new thread to discuss that.
br
ChenJian
