Hi
**• Hardware Platform - jetson nano
**• DeepStream Version - 5.0
**• TensorRT Version - 7.0
**• jetpack Version - 4.4.1
I am trying to only stream mipi camera using jetson.utils, By referring [jetson-inference/aux-streaming.md at master · dusty-nv/jetson-inference · GitHub]
I was able to stream it through the python script (i.e video-viewer.py)
Now trying to invert/flip the camera stream able to do with “video-viewer csi://0 --input-flip=rotate-180” command.
How can i achieve this through the same python script.
The post you are referring has a solution what you want.
https://github.com/dusty-nv/jetson-inference/blob/master/docs/detectnet-example-2.md
You can make a simple object detection code with only 10 lines!
Yes, i am able to do that
But trying to rotate/flip the camera feed in same script.
You may try something like:
camera = jetson.utils.videoSource("csi://0", argv=['--input-flip=rotate-180'])
Thanks, it works.
Also got this line for accepting the input
camera = jetson.utils.gstCamera(1280, 720, "csi://0")
What's the difference between them.
Also observed frame rate is 29-30 FPS through
1.cmd command (video-viewer csi://0)
2. camera = jetson.utils.gstCamera(1280, 720, “csi://0”)
But using " camera = jetson.utils.videoSource(“csi://0”, argv=[‘–input-flip=rotate-180’])"
getting 2 -3 fps.
Why is it happening or doing some wrong.
I can’t tell what’s happening in your case. My jetson-utils version is not up-to-date, it only support the arg parsing format, while older versions were using the (width, height, URI) format.
You may try to specify your video options such as:
camera = jetson.utils.videoSource("csi://0", argv=['--input-flip=rotate-180', '--input-width=1280', '--input-height=720', '--input-frameRate=30'])
Thanks for the reply.
I tried this but didn’t saw any significance difference by adding ‘–input-frameRate=30’
in the arguments.
In my case, 10 lines of detection example shows 15~16 fps at 5W power mode not MAX-N 10W.
I tested it in the docker container.
